Portable Sheds
Printer Mike
Eatonton, Georgia
I see these all metal sheds for sale in a lot of places here in Georgia. Seems like they are priced around $695 for a 12 x 18, installed.
Anyone have any experience and/or advice? Thanks...
BBQ&Love
Texas
Are you talking about the carports?
BBQ&Love
Texas
They are pretty much junk, slapped in by subcontractors to a company that you will have hell with when you have problems. Whatever you do, don't put anything valuable under it. Seen too many come down with a little wind. Hopefully at least the foreman on the job will speak English. If the Border Patrol comes around mid project your carport won't get done if you get my drift.
(I was in the carport business for a short period of time. Sold the business but I notice carports all the time yet.)
5lima30
Mountains of Western NC
I can tell you that they didn't hold up well during hurricane Ivan! There were a bunch in this area that wound up in pieces miles away and we were over 400 miles from landfall. YMMV.
Daniel Dudley
I expect that they would hold up much better if they were anchored to a few concrete plugs, or strapped down like they do trailers. Most are just set on the ground. They will take a snow load, as they seem to have weathered the past winter here in eastern NY.
BBQ&Love
Texas
I have seen 6" of heavy snow take these cheapos down. There are decent carports out there but these $695 ones aren't it. They are junk.
To the OP. See if there is a Waldrop dealer near you. They have the strongest carports of this style. They have a plant in TX and I think in Alabama.
John in OH
SE Ohio & Eastern Virginia
I purchased three of these carport sheds about 5 years ago for storing some farm stuff. Two are 18 x 22 and the third is 18 x 24. I bought the optional 6' high sidewalls, full sides, and single end closure. So they are basically three-sided sheds. They have held up OK against normal winds and SE Ohio snowfalls.
I've been very satisfied so far, but there are several steps you should take to assure some degree of satisfaction.
-- First, be sure the ones that you buy have corner braces and collar ties. I've seen a LOT of these sheds in the South that DON'T have the braces or ties and they look pretty flimsy so choose your supplier well .... they aren't all equal .... compare frame member size and gauge.
-- Second, make sure you prep a level site and put down a gravel bed with a vapor barrier.
-- Third, make sure the sheds are well tied down. At a minimum, use five, 1/2" rebars about 3' long with welded top nuts, on each side, and drive them through drilled holes in the sill member into the ground (the guys that install the sheds should do this, but you should check what they use and how long the rods are) ... check them periodically to assure that they don't work out of the ground. Another option available for the tie-downs are screw anchors that can be twisted into the ground ... don't know how well these work.
-- If you get sides or an end, orient the building away from the predominate wind direction.
The day these were to be delivered, a guy that could barely speak English calls me for final directions. He and a buddy (totally non-English speaking) show up at 9am with a pickup and a trailer of material. They worked non-stop (except for a 15 min lunch break) and drove away at 3pm with all 3 buildings complete!!
The sheds are most satisfactory for my storage purposes, .... but you get what you pay for. Just some thoughts and suggestions for your consideration.
supermerle
Arkansas
The shed I have took a direct hit from a 100' foot tall tree and survived? There's a guy down the road who finished his off and enclosed it and its not a bad looking work area. Hot in the summer but its better than nothing?
P
Printer Mike
Eatonton, Georgia
Thanks for the info.:thumbup:
I need some covered storage at a lake lot. Probably will be building a house and garage in the near future. I figured a portable building might could be moved later if I changed my mind about locations of buildings.
Razracing
florida
hello,
check out www.carolinacarportsinc.com. They have dealers in most states and they have an online price estimator that allows you to customize the carport/garage to your needs and you'll know exactly what it will cost you. I had one installed on my property when i lived in South carolina for a year and I'm planning to have one installed here soon. I completely enclosed it and made it into a low-buck garage. It looked really nice when I was done. You can order the carport any way you want> from a bare carport to a completely enclosed garage with a roll up door. I ordered the 21x18 unit and had them enclose both sides. To save money, I framed both my gable walls and made my own doors. For a floor I put down a vapor barrier and covered the floor area with 1/2" particle board so I'd have a firm floor for rolling a jack, etc. Yes, concrete would be way better but keep in mind i was on a very tight budget. I think I built the entire thing for 2k complete. The 21x18' size gave me plenty of room to work on my mustang with room for benches etc. I'm planning to put either a 18x26 or 18x 36 on my property here. The 18x36 will let me park two cars in it end to end.
Oh, as others mentioned , the crew that comes out to build the carport will probably speak limited english. They were courteous and worked pretty much non-stop. 3 guys total. The only problem I had at all was that the metal panels are held to the frame by sheetmetal screws with a neoprene type washer to keep water from leaking around the screws. some of the ones they put on my roof leaked after the first rain so I fixed them myself. You might wanna take a garden hose and spray it down while the crew is there to check for leaks. I'll see if I can find a pic of the one I put up . I had lots of pics of it another computer but it crashed and I lost all my photos. Like I said though , it looked great and I was very happy to have an enclosed space to work on my cars.
Razracing
florida
Unfortunately I couldn't find any pics of it after I enclosed it, but here is what it looked like right after the crew left. It's 18' wide and 21' long. I ordered the optional 7' legs which made it 10' high at the peak. I framed the end walls and sheeted them with T-111 , painted to match the metal siding the workers applied to the sides of the carport. By the way, if bracing is a concern, they also offer optional extra bracing. Ididn't buy it because once I enclosed the walls it made the building very stable. Oh, i also oredered the optional "boxed eaves". It looks much better than the standard roof.
Roy.
