remileblanc
this is a machinist's take on the snap-on hard handle mod. using a lathe and without cutting the ratchet shank.
start with taking the old hadle off the ratchet. i used a wrench on the bottom of the handle and pryed up with a prybar.
i then proceeded to wrap the new handle with electrical tape to avoid damage and scratches
i then took 4 1" wide parallels and taped them around the handle to make 4 even sides
then i used a drill that fit snugly into the existing hole to help to line it up in the chuck
then i drilled the hole to 29/64" and 2 3/4" deep this made for a little clearance for the 2 crimps on the ratchet shank
next was to drill 7/16" to 4 3/4" deep
then i used a countersink to make a chamfer to clear the rad on the bottom of the ratchet shank
the finished handle with tape and parallels removed
layed the ratchet and the handle on the bench to line everything up.
put the ratchet back in the vise put a rag on the new handle and beat it on with a dead blow hammer. the end result is a green hard handled SHLF80.
