Wiring tools.
durallymax
I cant seem to find much for a selection of decent wiring tools or know where to look at all. Ive searched on here but didnt get much. Im looking for tools for automotive wiring. Cutter Crimpers strippers. Looking to step up from the box store multi tool as its clumsy. Just looking for more options that may be out there that I am missing. I do a lot of wiring so buying soem good ones is worth it to me.
thanks.
Scuderia-F1
Stockholm, Sweden
There is some nice Blue-Point ones, I have one myself that I like (PWC-9). But the Snap-On PWCS 7 is also nice if you would like a little more compact plier.
kellyo
I use klien for my electrical tools. They can be found at home depot also.
JEEPLESS
MO
I have Ideal Stripmasters, one for small gauge (20AWG - 30AWG) and one for larger gauge (10AWG - 18AWG). My goto wire cutter is Xcelite 175M. Large gauge cables are cut with a Channellock 911. The Channellock 909 crimp tool works well for me also.
JustBob
Mobile, Alabama
These I would get first, then other tools as you find a need for them.
Thomas Betts Sta-Kon WT111M crimper/cutters
http://www.tnb.com/ps/fulltilt/index.cgi?part=WT111M
Klein crimper/cutters/strippers/ingnition wire crimper
http://www.service.kleintools.com/Tools/strippers
Ideal auto strippers StripMaster 1010(if you do alot of wire stripping, different configurations for different wire sizes, able to strip wire safely, replaceable blades)
http://www.idealindustries.com/prodDetail.do?prodId=stripmaster
Klein Cutters D228-8 Dykes (ability to cut wire close to work, cut in areas other tools can not reach)
http://www.service.kleintools.com/PLIERS-DIAGONAL-HLDIAGCUT/Product/D228-8
Jeeper
Round Rock, TX
I have one of these:
However, I took it apart and now I can't get humpty back together.
mp23
I have one like that from GB, I will never go back to the other kind of wire stripper.
Jeeper
Round Rock, TX
These Irwin pliers are the best I have used and you can find them at Lowes. Bought one pair and after I used them bought another just in case they change the design.
http://www.amazon.com/dp/B000OQ21CA/?tag=atomicindus08-20
Those are the ones I bought when I couldn't get humpty back together. I actually just looked at old humpty and I got them working. The only thing i can't figure out is the latch spring. It attaches to the top of the right handle (when looking at them like in the picture). But i can't figure out where the other end of the spring connects to. Can someone look for me?
JustBob
Mobile, Alabama
Which spring 7, 12 or #14? I can take a look at mine and take pictures if you need it.
http://www.idealindustries.com/products/wire_processing/hand_tools/stripmaster_parts_list.jsp
Jeeper
Round Rock, TX
JustBob
Mobile, Alabama
Latch spring (part #7 above diagram) goes between the latch (part #6 above diagram) and the back of the main body with the long leg resting against the main body hinge point. The short end with the hook, hooks onto the latch from behind and over the top of the latch. Here are a couple of pics to help illustrate.
View from the top (left hand side when viewing from the front)
Front view
Circled in yellow, this is a view from the back. This is the pin the latch and latch spring mount to.
dirtrider
Channellock has some nice pieces for electrical work, But when it comes to electrical I like Klein especially there lineman series. I recently bought a klein katapult automatic wire stripper and that thing is nice, better than any other regular stripper I have used.
tw33k2514
Chicago
my electrical tools consist of a pair of Klein 11055's, Channellock 909's, a Power probe PPSK butane soldering Iron,a Power Probe III. and a fluke 88 with an inductive clamp. Does all I need for automotive wiring.
brimorga
Bay Area, Ca
JASTECH
Gering, NE
I use Knipex, old Ideal, Wiha ins/14pc driver, Klein, Fluke and Simpson. I do have Snap-On and Channellock that are used in my trailer wiring kit. Replacable jaws on stripers a plus.
Thanks, JASTECH
eurokid
Tacoma, WA
I have one of these and they work pretty good. Strips nice and clean, actually cuts the insulation rather than ripping it off like those cheap jaw style ones. I've got a pair of the Stripmaster pliers as well.
Those Thomas & Betts Sta-Kon crimpers are awesome, best crimpers for automotive use by far IMO. I have tons of wiring tools, one of the things I've done and still do a lot of.
dwm
Southeast Michigan
The people I know that have spents lots of time building instrumentation panels, industrial control panels, etc. use Paladin Stripax Pro6 strippers (model 1113). I've been using one for 10 years and it keeps me happy. For today's vehicles, if you're touching wires behind the dash, you want something that works effectively down to 28 AWG.
I also like the Paladin ratcheting crimpers. For the big stuff (battery cables, etc.) I use a QuickCable HexCrimp 4255-001MR at home and a very old Thomas and Betts diamond crimp at work.
