Ingersol Compressor what are these for?
Motown 454
Ingersol Compressor
Hi I found a 7.5 hp Ingersol Rand 80 gal compressor I'm going to buy. Its part number 2475 N75 What are these transformers for ?
Here's a picture of the compressor.
Let me know what you think for $700
Thanks Wayne
Gooch
Petersberg, IA
they're buck-boost transformers, probably used to step a 120/240 single phase service down to a 208 single phase. would be my best guess without knowing the details on the compressor.
nehog
Jaffrey, NH
Someone (prior owner) had low line voltage. These transformers were used to increase the voltage to the level the motor requires. I'm guessing it is single phase, right?
$700? I guess this is a 'you ****' moment...:rocker: fantastic buy... Looks really good.
Motown 454
Yes single phase, and it is great to ****, thank you! lol
As far as the second voltage I didn't even notice that.???
ishiboo
Oshkosh, WI
Thanks Wayne
Those transformers do not go with the compressor. They're a 10:1 winding so they put out 1/10th of the input, ie 12v out @ 120v in, or 24v out @ 240v in. nehog/Gooch are waaaay off :)
Decent output rating, so they were probably used for low voltage lighting or hacked for a (poor) automotive/RV supply.
Compressor looks like a great find for $700!
Norcal
They are buck/boost transformers as said earlier, most likely to boost a 208V supply.
nehog
Jaffrey, NH
One needs to understand what and how a buck/boost transformer is used, prior to saying someone is 'waaaay off'. :bounce:
