Workplace injuries
Borrego
San Fernando Valley
Was just thinking back to when I was injured on the job over a decade ago - broke my ankle and tore a ligament stepping into a pothole. I even walked on it about another 15 minutes before something didn't feel right. Since I was a temporary worker at the time, I feared losing my job. However, after 3 months of limited duty, I was back to a normal duty assignment. Anyone else injured while on the clock?
ZRX61
Solar Blight Valley, SoCal
Yup, me & some ******** idiot carrying a Dodge 440 block. I couldn't see the ground so was reliant on him to lead. He stepped over a pair of cylinder heads & didn't think to mention they were there.. TRIP... CRASH.... just managed to let go of the block before it hit the ground. Blew out one shoulder & 4 discs...
crewchief888
NW indiana
ahhhhh let me count the ways
:lol_hitti
hot chip from a milling machine got behind my glasses, landed in my eye
cut/bashed my knuckles, ended up with a severe infection from the chemical fertilizer i was working in
20 stiches in my forehead right at the hairline
cracked ribs and severe bruising from a loader root rake falling and hitting me in the chest
broken ankle from a boom cylider stop falling off a tire
broke my own finger with an 8 lb sledge hammer
had a chunk of metal removed from my leg from a chipped pin hammer
fell and broke my ankle once again ( same ankle)
severely bruised leg form a loader bucket falling off a stack of buckets
more cuts, bruises, smashed fingers, and headaches than i can count...
:beer:
Gregg33
Port Colborne, ON, Canada
Years ago I was running late for work (I worked at hotel at the time) so I parked in a neighboring parking lot (a big no-no), so I could get to the punch clock quicker. I did make it in time, but on the way back out to move my truck to the proper parking lot, I jumped over a 3 ft railing and landed with my foot centered on a curb which was about a 4ft drop. The result was a broken foot. I somehow managed to finish the day, especially surprising because my job was a groundskeeper. That night the pain was almost unbrearable, but it healed up, albeit with the edge of a bone protruding. Never missed any work either. Definetly one of the stupidest things I've ever done.
Catalyze
New Mexico
Greased 4 foot length of 3 inch steel slipped in the sling and smashed the toe of my steel toe boot. Folks had to use a die grinder with cutoff wheel to cut the boot off. I changed careers shortly thereafter.
Craig (10 wiggling toes still)
Ritter4.0
Maryland
I just get cuts, nothing that I would consider bad. Mostly just "bad" paper cut type cuts. Apparently whatever is in the cutting fluid I use in the CNC routers is pretty clean. I have been working at this place for little over a year, gotten tons of cuts and not one infection. I just stop the bleeding, clean it with Simple Green, close it up with super glue and call it good.
diesel research
gulf coast, TEXAS
Burnt/cut/smashed, but never "recordable" or "lost time".
Many times in my deployment to the middle east, or time spent at the car shredder, I "thought" I was gonna meet my maker. lol
hofferwood
DownRiver Michigan
Oct. 27 2009
My son
The "coil" took his right hand and up to 6" below the elbow. Then landed on his foot.
That is the "I-Limb" , if you ever see the U of M commercial where the guy grabs the little girl's hand towards the end. Same type.
Chuck
jay50
Oct. 27 2009
My son
Chuck
What is the "coil" you are refering to?
kmkalf
Buffalo, NY
funny this thread came up, just yesterday i got out of a company car, and the whole parking lot was black ice, slip and sprained my left ankle, hurts so bad to walk on it and tomorrow at my other job is going to be all overtime if i can walk
diesel research
gulf coast, TEXAS
I was real suspicious when our clock continued to climb above 450 days even though I had known several people to get injured on the clock including a broken foot due to 250lb steel plate falling on his foot.
I then found out they were not letting them go to the doctor (more likely persuading them not to) until end of shift, and putting them in "light duty" office work for the remainder of the shift. They likely simply told the low wage worker "look if you go now, you are off the clock, and you don't get paid" and he probably chose to stay.
csargents1546
Westminster CO
More cuts scrapes and bruises than I can count. Wife ask me what I did? I just shrug my shoulders. Most times I don't notice untill I pick something up and wonder what that red stuff that looks like loctite is. I have a high pain tolerance almost to the point of being dangerous as I don't know when I hurt my self.
jeepntxj
I was on the second level of one of our concrete plants working on a clogged screw auger with a 48" pipe wrench. There were alot of clods in the product, so I had been up there for about 5 hours at this point. Back the auger up manually, turn on the power and run it forward until it clogged.
Just when I thought I had it broke free, I threw the disconnect back on and told the plant manager to run it. What I forgot, was the pipe wrench was still on the end of the auger shaft. It spun 180* and smashed my left hand on the electrical box I was leaning on. Broke the bone that runs from the wrist to the pointer finger.
2 years, 2 surgeries, a plate and 8 screws, and 12 weeks of physical therapy, I'm back to about 90% now. Cold and humidity make my hand throb and swell, and I can predict rain better than the weatherman can.
Txchevy18
Texas Gulf Coast
About 2 months ago I was blown off the deck of a 90 ton crane in a local oil refinery while changing a hydraulic holding valve on a boom cylinder that was bleeding off. The valve and cylinder were supposed to be dead with zero pressure but, when we pulled the last bolt a stream of fluid came out and hit me in the face. I dropped my shoulder to get out of the way and ended up on the ground, about a 6ft fall. My first thought was fluid injection, luckily the stream was a large burst and not a small contained stream. Ended up in medical covered in hydraulic oil. Meat wagon took me for ct scans and doctors review. Some how I walked away with a concussion and a sore shoulder, I was damn lucky.
It ended up an osha record-able, turns out the safety department didn't even know that there was a heavy equipment crew much less where the shop was...they do now. Also seems my company had none of the paperwork from a safety aspect on their end for our department and was caught with their pants down so to speak with osha. Sadly we still aren't in compliance 100%....After review they still can't figure out why it happened exactly. My best guess is an internal failure inside the holding valve causing an unequal balance of pressure between the two sides of the cylinder.
bobcatdan
Kaukauna,WI
Removing a 3 point draft arm on a JD 2750, the pin connecting the lift linkage was stuck and had to drive it out. When the pin popped out, the arm swung down and smacked my foot. It dented the steel toe and my little toe turned black and blue, but I still worked on it. I took the day after off because my other foot started to hurt from favoring the other.
Roots
As a former corporate safety rep, with the exception of a handful of companies, I tend to shiver at the thought of how many facilities treat their partners-employees when I see Lost Time/Injury clocks like that. It's terribly callous how many major companies treat safety, even if they publicize it as a core value.
BTW, that persuasion you allude too could very well be likely illegal in your state. Unfortunately, and not to go political, but Texas isn't particularly big in balancing workers rights and corporate profits.
Personally I've never had a lost time injury, however I was knocked to my knees once from touching an ungrounded fence in a high voltage environment. I promptly reported it, but had I known better at the time I would have insisted on an EKG immediately.
930dreamer
Amarillo,TX and Stinnett,TX
I pulled the only living family member(not mine) out of his burning car after it was rear ended by a semi(while on the clock). I received some burns and glass cuts, I also was sent the bill from my employers medical unit. I almost lost it.
theoldwizard1
SE MI
A homeowner submitted a bill to the city for replacing his front window and door after he acted as the police spotter for an armed gunman situation. (One officer and gunman killed in the shoot out.) He was initially turned down.
Lump
Jamestown, Ohio
I used to be a sheet metal worker. Too many cuts/stitches to bother listing.
But today I worry more about long-term "work-injuries" I may be carrying. On several occasions we did lots of long soldering joints, spending all day melting and vaporizing lead and tin, and we were breathing those fumes. We were also constantly dipping red-hot irons into muriatic acid to "tin" them. Sometimes the breeze through our shop would suddenly shift, and then acid fumes would fill our lungs and choke us to the point that we would drop an iron and run several steps away to get a breath of real air. That CANNOT be good for you...
Also, when they tore out Frigidaire factory near here, I spent several days cutting down the walls of the old giant room-sized conveyor-based ovens where they had baked on the porcelain finishes to appliances. The walls were stuffed full of asbestos. We used torches to cut apart and tear down the steel walls, and the chicken wire which held the asbestos in place. When one of the big steel siding-type walls would crash down, the whole 200-foot-long rooms would instantly fill with asbestos "snow", which was so thick we had trouble seeing each other across the room. That part of that job lasted for about a week. All we had were those little white 25-cent face masks with rubber bands to wear, but the black soft soot from the walls quickly clogged them. All of us had soot-blackened spit for days afterwards, no exaggeration. One of us might happen to spit onto a white place on the concrete, and everyone would chuckle at the blackness still present in the saliva. But in our private thoughts, we all worried about that.
Add to that the years I spent using compressed air to blow brake-shoe dust off backing plates, and power-grinding brake shoes to match the radius of brake drums and...well...I sometimes wonder/worry if that will come back to haunt me one day...
oilslick
Central illinois
I was rmoving window motor on a windstar and forgot about the spring in the regulator until the last bolt came out, whap it came around and felt as though my arm had been broken but it was just a bruise and cut, so be carefull everyone.
mooman
CHICAGO, IL
As my company's corporate safety manager, I'm getting out of this thread quick!
I see enough of these during the week.
Amitygravel
Claremont Illinois
All of my injuries have happened while self employed.
Head butted a sprinkler head. The fins obviously cut the hell out of my scalp , but the impact of hitting the sprinkler hurt worse.
First thing one morning , was dragging a 200 lb 4x6 chunk of steel tubing to get it ready for one of the garage doors we were installing
to open out to the patio from the bar area. Got tripped up and fell. Damn tube landed across the arch of my left foot.
Felt like someone had a blow torch aross my foot. Pulled my boot off , no broken skin at all. Put my boot back on
And hobbled back to work. Worked the next two days limping aroun still getting stuff done.
That happened in Columbus Ohio , went home for the weekend and on Sunday finally went to the E.R. And spent 750
bucks for them to tell me my foot wasn't broken.
Two years later while working in Indy on another bar , was on a painters scaffold that was only set at a height of
3ft. The platform came loose and I fell through on the same left foot. Lots of pain , swelling and limping then too.
That was about 3yrs ago. That foot bothers me all the time now.
Learned a long time ago not to get in a hurry for anyone. No matter how much they ***** about getting something done
That's when stupid stuff happens and injuries occur.
bobcatdan
Kaukauna,WI
I thought of another good one, Scraping a gm car at home, I didn't have a puller for the harmonic balancer, so I used a fire puller. We were having a bond fire that night, so there was about 10-15 guys in the shop. Like normal, I'm the only one really doing any thing. The engine is out hanging on a cherry picker and I have a brand new green drain pan the engine thats still leaking a lot of coolant. As I start cutting the balancer, I notice sparks and slag hitting that new $5.00 pan, so I move it. That is when I notice my right hand is directly under the torch, I think to myself, that is not go and removed it from that spot. It was a pretty good size burn, I didn't do anything about until the next day when I had to peel my hand from my bed sheets. I finally wrapped it up. Pretty disappointed by the scare, can hardly see it and the hair grew back. Yes there was beer involved.
Chadro
Eastern Missouri
I had a 79 F150 I bought for $700 right out of High School, was turning it into a mud bogger so I ended up getting some 42's to put on it. Well I was at a buddies house so I didn't have my high lift jack or any pieces of wood to get it jacked up high enough to put the tires on so I used cinder blocks (retarded).
Well I was wrangling one of the front tires on and had my arm on top of the tire when the blocks gave way. Pinned my arm between the tire and fender until the tire finally kicked sideways and I went rolling down a hill. My forearm was almost completely black and hurt like the dickens. It wasn't broke, though. I'm guessing that since I was 18 and put down 1 1/2 gallons of milk a week, my bones were good and stout lol.
That's about the worst injury and it wasn't too bad. I tear my hands up at work all the time but nothing major.
diesel research
gulf coast, TEXAS
No, you are right, I know the political climate full well. Live by the sword, die by the sword.
As far as the legality, I suppose it all depends on what exactly was said to persuade this individual to sit in pain for 6 hours before going to ER off the clock. (maybe on his own dime, idk, I got the hell out quick after that)
I'm sure mentioning that his safety bonus was immediately cut played a part as well.
theoldwizard1
SE MI
My employer ended up taking care of it with no issues.
The city paid him after it hit the local news and papers.
gjoe
northern, ct
not allowed to be injured on company time..........this a is the rail industry standard.......
Know the feeling. I work in a small jet eng O/H shop, and we have safety discussions for 15 mins, at the end of each shift, for the past 2 yrs. If someone gets cut or bruised, we have to shut down production, and reorganize the shop B4 work can continue. Upwards to 6 or 8 hrs. I don't like seeing injuries anymore than the next guy, but talk about over the top.
cool50
Il
I slipped in oil and went down HARD! I soon realized that my right arm did not work. 5 and a half hours later they told me at the ER that I fractured my neck. Although that was over 10 years ago and everything is good, sometimes I still feel that old injury.
tatra
pirate contest city
was a time if you got injured, the idea was to find out what and why it happened, noe it is to place blame and use peer pressure to bully employees into not reporting an injury...........don''t wanna miss out on your dried out tony roma's rib dinner or a chinese leather jacket............alao, i was injured once and got full pay as long as i took a taxi into work, had it wait for 10 minutes and then went home after checking in with the senoir supervisor so they could technically clain not a lost time injury for fra standards as i was on the property daily...........any place that has those *** number of days w'o a lti is full of **** and hiding the truth........never had this problem until we started being influenced by american magmt..........
diesel research
gulf coast, TEXAS
My mother works at a oem automotive parts supplier (they build interiors for a wide range of oems) in michigan
Was walking in the door, slipped and fell on the ice, busted head. Got a $2000 ambulance/er charge+ related medical expenses. Tried to pass it on to the company. Informed her they are not liable and will not be paying. Talked to several of those injury lawyers. Not a single one would even touch the case and explained the same thing the company did, they are not liable. Come to find out, it was because she hadn't made it in the door to punch in.
On private property an individual can be liable for injuries even if the person is trespassing, but in this case, if an individual is not on the clock, an employer isn't l;liable. I'm sure that varies by state. If the person is a visitor/customer, I believe the liability is on the company though. Strange loop hole.
Vinko
Los Angeles
What's a "partner-employee" ? One thing or two separate things?
I'm on the mailing lists of a lot of the safety trade mags, but I've never seen that phrase used.
