Fastening Sill plates to concrete
wfopete
Somewhere North of Dover, AR
I put in studded walls (16" OC) in my pole barn. I need to secure the sill plates to the pre existing concrete pad which is 4-6" thick. What is recommended? I thought hammer drill and wedge bolts but there may be better options.
royalton10
Lancaster, Ohio
I have seen a Hilti gun (sp?) used. Don't have one and not sure of cost. It basically uses a charge similar to a 22 rifle to fire what looks like a pop rivet. At our church the Hilti was used to attached a metal track to the concrete floor. Then steel studs were used, sheet metal screws attached steel studs to the metal track on the floor.
Thruxton
Virginia
I have used one of these for a number of years, they work very well if the concrete is in good shape.
W
wfopete
I looked at a "Nail Gun", it took 27 cal shells and could fire up to a 3" nail. You could load 10 shells at a time. I just thought a wedge bolt would provide better holding power.
Dragster Racer
Morrison, IL
You know, I have one of those nail guns, and I have terrible luck with it. I never seem to get penetration or holding power. Oh Lord. Now it sounds like a personal problem.
mobetta
twin cities, mn
depends on what tools you already have. powder actuated nailers are nice, but the cheeep ones are ****. most peeps have a hammer drill.( well, most peeps around this site) wedge bolts will be stronger, too.
ddawg16
S. California
Epoxy. Drill as above.....but don't use a wedge bolt....use an anchor bolt....you get those and the epoxy from the same place....the epoxy comes in a two part tube....it mixes it as you squeze it into the hole...insert anchor...let it dry.
Once it's cured....that SOB is not coming out.
ducati
Use these:
http://www.powers.com/product_7204SD.html
The only problem is you have to use their drill bits, standard size concrete bits won't work. This way at a later date if you need to move a wall or change your layout, just back the fasteners back out.
If you plan on using a standard wedge style anchor, drill the whole all the way thru you slab, then if you move a wall you can just take a sledge and beat the fastener down flush.
I have a Hilti 27cal gun, if I know for a fact that a wall will be permanent, I just use it, it holds quite well.
jkeyser14
(rural) Maryland
I tried the powder nailer approach in my garage and used ramsets reccomended size and powder load and had nothing but trouble with it spalling and pulling out. I wound up using tapcons and the wall is solid as a rock.
ForceFed70
BC, Canada
There are 2 common approaches in my neck of the woods.
- A TAPCON style bolt is often used by a DIYer who doesn't want to buy a hilti gun. All you need is a hammer drill.
- The pro's use a hilti gun, but only because it's fast. I prefer a TAPCON style bolt as it is removeable and holds better IMO. IN reality, all you need is the sheer strength so holding power really isn't a consideration.
http://www.tapcon.com/
slip knot
Texas gulf coast
Don't drill all the way thru the slab. Your just introducing a moisture/termite entrance issue. If moving a wall becomes an issue later just grind off whatever sticks up out of the slab.
ForceFed70
BC, Canada
Wedge or epoxy bolts, the shots shatter the concrete when they enter. Tap cons will rust out in a few years.
Code in my area says you must use tapcon if anchoring treated lumber due to the improved corrosion resistance. I really don't think corrosion is a significant problem with a tapcon. Especially since the norm is a standard concrete/hilti nail. My last house was 40years old with nailed sills (interior walls) and they were still well fastened and a PITA to remove.
ducati
If you have moisture or tirmite issues, you have a bigger problem than beating a 1/2" wedge anchor down. I'm not saying to beat it all the way through, just flush. The anchor will still keep the whole plugged.
Tapcons are ACQ rated. :thumbup:
Also available in an ACQ rated nail
Rick98Z
Eastern Shore, MD
When I did mine, someone gave me an older but free nail gun with shells and nails included so I went ahead and used it. I also applied construction adhesive on each board first before I nailed them down just as extra precaution. I never thought about corrosion on the nails though going into treated lumber...I might go back sometime and add some anchor bolts just for shits/giggles.
CBO
ITW/redhead wedgelocks work well, Simpson Titen bolts and if using shots they should be 3" with 1" steel washer starting 6" off plate breaks then usually no greater than 24"oc for load bearing walls. Check nails box for maximum spacing as well....usually based on nail diameter!
BC1
Temecula CA, plotting my escape!
wedge bolts are easy and quick, especially with a roto-hammer to drill it. the load is all shear so i don't understand why you would be too concerned with them pulling out.
tcianci
Walpole, Ma
The OP said he put stud wall sin on 16" centers in a pole barn. There is no load bearing force on this wall and indeed all he needs is a little shear strength to keep the sole plate of the wall from moving. If he doesn't have access to a 27 cal. Hilti his best bet would be simple Tapcons. A lousy 1/2 inch of engagement will be fine, any hammer drill will be fine and he can install them with a rachet. It will probably cost less than 15 bucks to do the whole building. Many of the answers on here are way overkill and typical of folks who seem to like to turn a simple 5 minute job into a freakin career.
fergus
Yolo County CA
I used a regular old drill, plus an SDS (i think?) or impact masonry bit. Worked like a charm. Used RedHead anchor bolts to put a new sill down on my 80 year old garage concrete slab. No probs.
MTNFRAMER
Hangtown Ca
I am with Dawg, if you do not have a hilti or comparable drill, epoxy,anchor bolt.
Couple tips from an old carpenter- pre-drill thru wood then use mason bit, also stagger your holes it holds better than center holes. Another money saver over redhead or simpson etc. is threaded rod in epoxy.
retrobuilder
Alpharetta GA
Tapcons..but just drill slightly deeper than screw for avoiding drill through. Use the drill that is supplied by Tapcon. They have a good website with info. Simple and quick. You need a hammer drill for best drilling.
jkeyser14
(rural) Maryland
I tried using a ramset in my garage. All it did was spall the concrete or pull right out.
I switched to tapcons and had great luck (though it took a lot longer).
Oggy
Central New York
This. Hilti gun and be done with it. I used to work for Hilti, so I'm biased (against ramset/remington) like tcianci said though, if you don't have one of those simple tapcons will work just fine. Wedge anchors are overkill, if you did use them you could probably get away with two per sill plate.
Edit: Biased against ramset/remington because every one I've used has been ****. You can rent a Hilti at nearly every rental place.
ydna
Tcianci is right. Wedge anchors would be ridiculous for this application. Its a stud wall. Hilti gun or tapcons and forget about it. Both are perfectly adequate.
Red05GT
ohio
Drill a 1/4" hole with hammer drill, take two 16D common or galvanized nails side by side
and drive them into the hole. Cheap, quick and easy. We've used this system for temporary as well as permanent attachment for years. To remove it will take a cats
paw nail puller to pull out the top nail head first.
theoldwizard1
SE MI
I had one of my sill plates replaced with PT a couple of years ago. 1 stainless Ramset nail per stud bay. That baby isn't going anywhere !
Falcon67
Merkel, TX
Are there any codes on this, specifing size, quantity, distance apart, etc?
Since somebody woke up a dead thread -
On regular exterior walls - yes, UBC specifies. 1/2" galvanized J bolts - No more than 12" from the corners and 6' or less apart down the wall.
On a partition wall in a pole barn, no.
GarageEnvy
Fresno
The epoxy and wedges are probably the strongest of what I've used but for what you're doing the tapcon or Hilti shot would work fine. I've got the El Cheapo single shot powder actuated tool that you have to hit with a hammer. Even with a heavy shot, sometimes it won't drive all the way.
Wadd2
Again it's an old thread but I can't stop myself, lol. I have a Hilti gun and until I bought it couldn't understand how good they are. Heck even for load bearing walls. We anchor basement walls to the floor every house with a Hilti gun. The key to making them work is keeping them clean and in working order. I bought mine for $200 off of ebay and the seller stated it was used for 2 jobs and quit working. I took a chance and scored. Bought new seals and cleaned it up and it works perfect. Enough powder choices and depth setting on it I haven't found concrete it won't penetrate yet.
Spudland_Dave
Maine
3 Letters... LDT
I used 1/2" LDT's (Large Diameter Tapcon) all around.
Epoxy is strong...very strong. BUT a PITA to install, to do it correctly you should drill hole, blow it out, brush it out, blow it out, brush it out, blow it out...etc.. When time is money especially when your framing and such, you dont really need any "pull out" strength, just sheer strength.
Wedge anchors are good too...cant go wrong with those either.
Zeke
3 Letters... LDT
Best advice since the thread got started. Always blow out the holes no matter what you use. Wedge bolts will certainly work better.
I like the 2 nails idea. Never used that. And I've built some temp walls before.
W
wfopete
Ok OP update! Believe it or not I'm just getting ready to fasten the sill plate. A key part I left out is:
This is a 30-foot wall with a double door in the middle of the span. My concern is the constant opening closing of the door and how that will affect (effect?) the choice of method for holding the sill plate securely.
theoldwizard1
SE MI
I concur, but you must get the CORRECT epoxy !
Remember when part of the ceiling in one of Bostons Big Dig tunnel collapsed because they used the wrong epoxy ? !! :shocking:
theoldwizard1
SE MI
Interesting. Good for temporary, but unless you are using hot dipped galvanized nails or better yet, stainless steel nails, it will rust out from the moisture in the concrete,
