No more cold winters
pl_silverado
West Bradford, PA
I scored a kerosene torpedo heater on craigslist for $ 200....
170,000 btu's of heating power for a 1 car garage... oh boy :bounce:
Doesn't look like its been used much, the guy said only a handful of times since he bought it and i beleive him.
This thing is going to come in handy when i get around to building my garage ;)
Its this model on the website
http://www.reddyheat.com/productType.cgi?type=2&target=10120.2.2-3-&sub=10120
Runs on diesel, kero, fuel oil, and jet fuel.
I'll snap some pics and post them later on.
PAToyota
South Central Pennsylvania, USA
Only problem with kerosene heaters (or maybe I should say one of the problems...) is that it tends to coat everything with an oily film...
I used one during construction, but sold it when I started putting the drywall up.
5wndwcpe
Southeastern, PA
Kero heaters don't fully burn all of the fuel until they heat up some. If you look into the outlet end, you'll see it glow after it runs for a bit, this is what completes the combustion. I usually start mine outside and let it run for a few minutes and then bring it into the shop. Stinks a whole lot less that way. :thumbup:
P
pl_silverado
West Bradford, PA
Yup. I've done that in the past too.
P
pl_silverado
West Bradford, PA
I never noticed that! I'll keep it in mind.
Either way, i dont do much in the garage during the winter, but im going to be glad i bought this thing when i do need to do something this winter. I hate working inside in the cold.
P
pl_silverado
West Bradford, PA
Realistically i could have been fine with a small 4000 btu unit for the single car garage, but i see a garage build in the future so i think i'll be happy i bought this ;)
mhoffm911
I use a product called Klean Heat in mine. It's semi-odorless. While it costs more, I don't have to listen to my family whine about the smell. You can buy it at Home Depot.
P
pl_silverado
West Bradford, PA
Is that what you fill it with or is that an additive to the fuel?
edit, i just read it is the fuel.
How much does that go for per gallon?
mhoffm911
It's not cheap. It's like $8-9 per gallon. However, it's worth it to me to not have to listen to them complain about the smell. I have used it in mine for at least 3 years and have never had a problem. We have also set my heater up at auctions and have less complaints buring this fuel than when we would use kerosene.
Note: I have never mixed it with kerosene. My current heater has only had this in it only. I don't know that it matters, but thought I should probably mention that.
P
pl_silverado
West Bradford, PA
Woah...i didn't think it was gonna be that high. At that much, its gonna cost $ 110- 120 to fill this baby up.
I'll keep it in mind though if i start getting complaints, until then reg kero it is.
kbs2244
They are noisy.
They put a LOT of moisture into the air.
They put a lot of CO2 into the room.
And they make the place warm.
Be careful and enjoy the warm.
Charles (in GA)
50 mi south of Atlanta
Run Kero or Jet Fuel, they burn much cleaner than diesel, which I would only do as a last resort.
Don't forget, these things produce carbon monoxide, if running it in a closed garage, you need to raise the door six inches or so to get some fresh air. Take breaks occasionally to see if you are OK. Get in some fresh air for a while and you will have a headache if you are getting carbon monoxide. If you sense a headache or anything wrong, open the door fully and get outside, even if it is cold, call for help.
CO coats your red blood cells so they cannot adsorb oxygen, takes a long time.... hours to work out of your system.
I've received a good headache from mine before, won't let that happen again.
Charles
engnerdan
Minnesota
Get the clear kerosene (rated for home heating), not the fuel grade that is dyed red. Still smells but not as bad.
Dan
kbs2244
Just reaalize you are dumping a whole lot of moisture into the air with those things.
Any tools need to be well protected from rust.
malibu101
Walnutport PA
Dan
I'd like to get clear again! Around here (the places I've looked) everything is red. Even home heating kero is red, most places here call it "Red Thunder".
I've tried running home fuel oil through my 55K BTU Reddy-Heater. It worked fine BUT the smell was almost unbearable. I now just use red kero from the local gas station.
P
pl_silverado
West Bradford, PA
I've seen clear kero somewhere around my way, i just can't for the life of me remember where it was. The place 1/4 mile from me sells red, since its close that probably what im going with until i figure out where the clear stuff is.
