jensputzier
G-day
I am new here but have a few Hazet Tools
[/IMG]![]()
[/IMG]![]()
Cheers Kevin
Kevin,
wonderful tools! Also you seem to have better weather if the temperature of 36 degrees is right ;-)
Cheers
Jens
G-day
[/IMG]![]()
[/IMG]![]()
Cheers Kevin
Yes could use some of that rain they've had over east , hasn't rained in Perth for about 8 weeks now.Jens,
Yes the temp is 2.45 this afternoon inside my workshop
I think that I am almost over summer, who said that the world is cooling
Cheers
Kevin
Well with Chernobyl the reactor blew up in April and the concrete/lead tomb was not in place until October.That radiation is going to be blowing across for at least a few more months.Who knows how bad that thing is going to get , it's all cumulative of course (the radiation).i do not think you want any rain today. they have found radiation in the rain in the US according to the news.
btw. Festool: this Festool "Autoloader" screwdriver is made in Canada
No longer made in Canada.![]()
Jens,
Cheers
Kevin
Woww!! nice little pliers + scissors from Engineer..do u test it to grab a screws?
it really works?
Btw: I like Engineer steel material it very hard right!![]()
mrtools,
I used the Engineer PZ58 screw gripping plier a couple days ago to hold two threaded shafts (with a thin round cap) that accept phillips screws to secure a handle on a bathroom shower door. The gripping teeth on the PZ58 worked better than the PZ55 to hold the threaded shafts in place while I tightened the phillips screws on the back of the shower door handle.
Dave
Proto Insulated Screwdriver.. maybe monte like to see![]()
G-day
Cheers Kevin
Does anyone know who's the manufacturer of those screwdrivers? Looks a bit like Wuro/Athlet, but are they?
Heres mine.
So here you have, enjoy![]()
i bet they are
Ok, thanks Monte. I have this one and wasn't sure about it.
USH only make bits, i think the pictured screwdriver is from Wuro/Athlet but could be from HKR too
www.hkr-werkzeuge.de
http://www.hkr-werkzeuge.de/2Komponenten.htm
Hi all!
Never heard of HKR.
Oh Muchas Gracias Bhae por toda la informacion que brindas ,visite tu blog muy bueno ,excelentes articulos de historias de las marcas,los videos de Craftsman algo "letales" hahah ah,tengo 27 años ,y me arrepiento de no haber comprado herramientas desde los 17 años hehe ,por estos lares admito que soy un fan de las heraamientas,soy mecanico de transmisiones de camiones (embrague ,caja de transmision,corona,cajas de timon ) y cada fin de semana me escapo al mercado a comprar una herramienta nueva,admiro las americanas pero gracia a este foro he conocido las Europeas y tambien japonesas (Nepros) y creo que voy alimitar mis gastos hehe porque si no me voy a quedar sin cuenta bancaria hahahah,estamos en contacto Saludos
Orlando
V!
sweeeet !!!!! I love Lambos !!![]()
Sweet... was that lambo covered in Oracal flat black wrap vinyl?
Nice homework for a nice toolsWoww!! nice little pliers + scissors from Engineer..do u test it to grab a screws?
it really works?
mrtools,
Dave
Btw: thanks bro
Hi all!
Well, as I said, I was in a trade fair last week, but that fair wasn't at all related to tools (or not directly). The fair was Graphispag 2011, a fair for graphic arts, so all of you can think what could anyone find there... yes, you are right, lots of printers, plotters, computers, presses and digital presses....... and loooots of germans
The only tools that I found there, were the ones a technician was using for fixing a digital press, but I found something that could be interesting for you to see, given the fact that you like italian "tools".
Nice Italian made supercar..
have u seen any Beta tools inside a car?
Btw:thanks to share a pics
yes i like to see !Thanks for the pictures !!!!!!!!!!!!!!!!!!!!!
Ur welcome!!!!!
Picard auto body hammer
I like a dark brown wood handle very nice one
thanks bro for a nice pics
Btw: im not a autobody mechanic but i know this is a very good stuff![]()
Thanks Theloniousmonk, well, I don't know what oracal is, but it was covered partly with a flat and matt black and partly with a carbon fibre imitation vinyl.
There was some exibitions of the process of covering the car (at a given hours), but I only was there to take some pictures of the car, was not interested on the process![]()
Today I visited MOTORTEC, but it was a very quick visit and I've only taken pictures of the tool stands.
Every car/motorcycle has to pass the TÜV inspection every 2 years. Is the car new the first inspection is after 3 years then every 2 yrs. The TÜV checks everything from the brakes, tires, wheels, frame/body, exhaust system, steering, shocks, lights (function , height adjustment) , wipers, horn, windshield, mirrors, seats, belts, and all safety systems (air restraint system, anti lock brakes etc.) plus the electrical systems (if OBD equipped car). They also check for rust/corrosion (underbody, structual parts, brake lines, suspension). They perform a brake test (machine looks like a dyno tester) , they they have to work evenly and surpass a certain value. They also perform a emission test and the proper function of the catalytic converter to see if the emission is within legal range.
Then they fill out a inspection report were the defects are written down. If the car is ok you pay your $122 and get the new stickers on your license plate . If there are any major defects you have to repair them within a month and they will check your car again and see if the defects are removed.
so if you drive an old jalopy with rust or many defects the inspector may look closer , if you have bad luck he will pull his screwdriver and try to pierce through the rusted parts. But most modern cars have zink plated bodys so thats more a problem of cars from the 80`s or 90`s . But nothing holds up forever so on older cars there is always something wrong like rusted exhaust system, steering linkage, shocks etc. So if too many defects occur it might not pay off to repair it since you can expect to pay about $80.- an hour (cheap) or if you drive to mercedes or audi etc. you pay around $ 130.- for a mechanics hour, so if you cant repair it yourself and have to hire someone its gonna be expensive. The other reason to scrap your older car is you pay more tax because they have higher co2 emissions .
Bhae para El Presidente y Gran Líeder! Ok, maybe not but thanks Bhae.Today I visited MOTORTEC, but it was a very quick visit and I've only taken pictures of the tool stands.
*snip*
Who makes some good jewelers screwdrivers?
The Germans.
Btw:thanks to share a pics![]()
.Man, talk about a government gift to the repair industry and the new car makers... I guess that is one way they keep their unemployment figures lower...
