Pneumatic Drill Recommendations
spartan1
Hello,
I am in the market for a new pneumatic drill and was looking for recommendations from you guys. I would like a reversible drill with a 3/8 chuck that has good throttle control. looking to spend under 200 and would prefer a USA made product but would also consider european brands.
spartan1
Should also have included that this is for use in a machine shop and would be used quite frequently
YellowLakeWelding
Wisconsin
Hello,
I have a Matco 3/8" and 1/2", no complaints here on both. They are the same drill just with different chucks, both jacobs chucks I might add. Repair parts were readily available the last time I rebuilt them also. I picked both of them up used in really nice shape for under one Ben Franklin each. A nice right angle 3/8" is in my future though...
jjjrmx5
Cincinnati, OH
IR 7802RA here.
http://www.tooldiscounter.com/ItemDisplay.cfm?lookup=IRAIR7802RA
Light to medium mfgr on shop floor and metal fab area. Ultra dependable.
I personally am not a big fan of pneumatic drills due to lack of variable speed in many of them. If going thru wood or plastic, no problem. Steel, or hardened steel requires a very slow and steady speed to get thru . If not variable then it;s wood alum and plastic only. For hard metals we use cordless or corded VS units.
the 7802RAKC is the updated version of above and around $200 IIRC. Replaceable parts all day long and IR quality. 7803 should = 1/2"
yaidunno
WI
I just picked up this little ****** (1/4") on ebay a few weeks ago for a little less then $100. I know alot of guys on here dont care for Mac, but this is a very well crafted and quality piece. Its got a two speed trigger with reverse, and its very controllable and has way more power then i was expecting. I'll be picking up the 3/8 composite in the near future.
http://www.mactools.com/Product/tabid/120/productid/329271/variantid/320030/Default.aspx
Hurricane_Whisperer
I like Sioux. US made, comfortable, compact.
Lots of choices at good prices from /http://www.browntool.com/
You will love an air drill. It is compact and the speed is high enough for the small bits used. Also the torque won't twist your arm off like a corded drill.
They really sink a bit, little start torque and plenty of speed makes them nice to use.
6530
East Coast
Lots of choices at good prices from http://www.browntool.com/
Link fixed.
Ritter4.0
Maryland
X2.
But get a regulator if you plan on drilling in thick steel. Air drills are usually pretty fast, and will ruin a bit in a minute or less.
Shipfittin
Portsmouth, VA
I've used quite a few IR pneumatic drills at work. Never really had a problem with them, and they get the **** beat out of them at my job.
Monte
Germany
Bosch. Made in Germany.
