Cruising the internet and found this place or should I say an old thread on the subject of the "green" Sears jacks. I've had this jack for 35+ years and don't want to have to trash it. (sentimental reasons). It was originally given to my Father as a Xmas gift and I inherited it. Very robust and reliable unit even though there were times I wasn't very kind to it. My problem started with a leaking/blown o-ring at the pump plunger. I removed the o-ring without any trouble. However I may have committed a major blunder. Before doing alot of research I decided while I had it apart, I figured a good flush of the old jack oil would be in order. I removed the plug/ screw covering the check valve port. The port to the left of the star gear to open/ close the valve for raising and lowering. With it over a bucket the fluid was running out slowly and I pushed down on the ram. Fluid blasted out. After doing some more research to locate a replacement o-ring I learned I had committed a major no-no. Back to the bucket where I store used motor oil and ran it through a fine screen to retrieve the two check balls and springs. I found the balls but no springs. I don't know if in fact there were any springs to begin with. I'm very confident that if there were any springs I would have found them but not sure.
Well I found a post by "BassNTruck" and a reply by "Hiball" on this particular subject. I'm looking for some info. Did these jacks originally have springs in the check valve assembly? Does anyone here have an old "green" jack they'd be willing to pop the cap at the check valve and take a peek for me and let me know if in fact there were any springs and if so maybe give me the dimensions? Maybe someone has a junk "green" jack and would be willing to give up the springs? I'm sure I can track down the o-ring locally. Hiball had mentioned he might have a line on someone who possibly might have a kit for this import Sears jack. I really don't want to give up this jack. It was Dad's jack. We had 8 drivers in our family and we did alot of brakes and and repairs with this jack. I'm really attached to this thing. Any and all help would be immensely appreciated. TIA
