DRC12345
I performed a search and was very surpised to see that there were no discussions on the usage of Lag Bolts or Lag Screws. I guess this is self explanatory, however, not so much for newbies such as myself
I am in the midst of building a garage storage loft abd am torn between using 4” wood screws or 4" Lag bolts to fasten into the rear and side wall studs? There are so many different kinds so I’m not sure where to start (#10, 12, 14 screws, 5/16", 3/18" lag bolts).
What is the procedure in drilling a lag bolt? Pre-drill one size smaller to accommodate the thread catching but not splitting the wood? Use a drill and tighten manually with a ratchet? Washers required?
For my purpose, what would you recommend?
