Well, today was fun.
My neighbors are great people, but getting older -- the wife is limited to her bedroom most of the time. So when I learned they were going to visit their kids this week, I decided I had to jump on cutting the concrete for where the lift is going to go. Their bedroom is literally about 20' from where I was cutting, so I thought now would be the most considerate time to make all this noise.
I'd never cut concrete before, and I knew this was probably going to be the most expensive step in installing the lift. The rental on the gas-powered saw and blade set me back $85. But I'll tell you, having a big saw for this is worth it. I was able to attach a garden hose to keep the dust to a minimum. In preparation, I used some duct tape and lumber to make a channel/guide around where I was going to be working so the water would flow out rather than underneath everything. This was a good idea, since the dust and water mix is not easy to clean up.
Still, it beats breathing concrete dust all day.
Here's the little water guide and approximate area I was going to cut. I ended up making it slightly larger than the tape indicates.
It only took about an hour to do the cutting. Picking up and dropping off the saw took more time than that. A 14" blade means a 4" pad can be cut pretty cleanly.
Here's the hole. It was funny to find a few live roots underneath it. It's got to be the driest part of the property down underneath there, and the pad has been in place since Calvin Coolidge was President.
I would also like to offer a huge THANK YOU to the workers of 1925 who were happy to
not use rebar in pouring this basement pad. It made my life much easier.
I cut a small channel for the control and power cords. I had to move my center island cabinets to make this cut.
Surprisingly, since the hole is a full foot bigger than the lift in each direction, the car is still just able to roll into its parking space. This is good, since it might not be until next month that I get to finish this up and pour the new concrete.
After I dropped the cutter off, I picked up the rebar I'll need for the new concrete. (My apologies to anyone who ever cuts into the newer concrete -- it
will have both mesh and rebar.) Home Depot also had the same tile as I used three years ago on sale for .68 a piece, so I grabbed another box. My outlay on this project is still pretty modest: $445 for the lift, $85 for the saw rental, $20 for the rebar and new box of tiles. So the current total is $550, but the cost of the concrete itself is going to add to that.
