File Handles. What to choose?
danc333
Southern New Jersey
My Amazon order has arrived. Now that I have more files then I know what to do with, I need to get handles for them. I am considering PB swiss and Snap on soft grip. I like the Snap on soft grip handles I have on my screwdrivers but at over $11 each I'm looking at $200+. The PB swiss handles look pretty cool and are between $4.50 and $7.35 each, but I'm not sure how well the would stay on the file. They look like they just press on to the end and perhaps have some type of barb in the hole to hold them on. I don't want wooden handles so I'm not considering them. Any thoughts, help or opinions would be great. Thank You
Dan
HandyManny
Out West
I've always used Lutz wooden handles available from my local Ace. They seem priced right and are comfortable in the hand. Just my input.
JimDon
Used golf balls, if you like a round file handle. Drill a pilot hole the appropriate size for a tight fit, about half way into the ball. Pound on the rest of the way. May not be the prettiest handle ever, but is functional, will keep the file tang from becoming part of your anatomy and is very low cost.
Just a thought.
Cheers,
JimDon
Steve_P
the nicholson ergo handles are nice. They're $4-5 each so they'll add up. I found the best price locally at lowes.
TheGrooveking
An alternate reality in a parallel universe.
Files handles a must!!! Glad you are thinking about them. I've got a little story to tell.....
way back when I was in my early 20's I worked part time at a mold shop doing rough milling and grinding and other machinist work. Well I started at 4:00 p.m. and some of the guys from days would leave at 5:00 p.m.. So this day I come in and there is bunch of blood all over the floor and one the chuck/bed of lathes. I come to find out that one of the moldmakers was using the lather and he cut off a part and then usd a file without a handle to break the edge of the piece in the chuck and when he got a little to close to the chuck with the end of the file, it pushed the tang into the base of his palm and into his wrist.
So the guy returns to work 8 weeks later wearing a glove on his injured hand, this time he is drilling a 2" diameter hole into a 4" thick steel plate on a Ooya radial drill. Sure enough the bit has two huge three foot long chips whipping around and he reaches over to break them off. Not a good idea, the chip grabbed his glove and that then pulled his thumb off, including the tendon from completely up his arm!! I'm in the back of the shop and I hear screaming and run up to see him standing there with his thumb and tendon spinning around on the 2" bit. The shop foreman hit the stop button and they called the ambulance. He ended up loosing his thumb, he ended up retiring after that, which is a good thing because at the rate he was going he was going to end up dead.
So the lesson learned from this story is, - use a handle on the file.
TheGrooveking
UncleJoe
New Bern NC
Enco has MADE IN USA file handles like this
Price is $1.89 each
Page 335 in their online catalog shows a lot of file handles at various prices.
HandyManny
Out West
Just a thought.
Cheers,
JimDon
That's a pretty good idea. :bowdown:
Major Ramifications
River Ridge, Louisiana
Grooveking, that was disgusting, but hilarious and educational.
I'll be watching this thread because I only have one file handle to my name and it always slips off. It's a Craftsman that has a tapered dealie that grips the tang as you tighten it. Now, with a bunch of Nicholson files that I don't need coming to me thanks to you guys, I've just got to get some more handles.
LincolnCont.
Uhmerica
Stay away from the RED PLASTIC NICHOLSON HANDLES...they don't hold for **** and they crack easily. I have Snap-On handles and am happy with them, although at 12 bucks a handle it does get rediculous. LoL! I did some modification to mine cuz the handles are too large for 6 and 8 inch mill ******* files so I removed the file inserts and placed them into two #1 SO screwdriver hard handles that I drilled out .
wreckercologist
cyber-tool hell
danc333: The Snap-on file handles screw on and are reusable.
TheGrooveking: That is exactly why I was taught to never use a file without a handle on a lathe. Scary stuff.
The Lutz wooden handles are fine, and comfortable, but I prefer the Snap-on for these reasons: Four sides. They won't roll off a table/work area when used with a triangle file or round file, and it is easier for me to control the file with the four sided handle.........not ragging on the other handles posted here, just pointing out why say that.
The old man used golf balls. Works fine, cheap, not too comforable IMO.
:beer:
rsanter
visalia ca
I have one of the snap on handles and really like it
with that said I gerw up using the old style wood handles and like those alot as well
bob
otis66
I use the same wooden handles I was taught to use in metal shop back in 7th grade 33 years ago.
