Can we make this thread a sticky?
with all the hf haters, that will never happen
Are the welding helmets any good??
http://www.harborfreight.com/weldin...sign-auto-darkening-welding-helmet-91214.html
Has anyone tried item 39178 the 450 Lb transmission jack? Does it have tilt adjustments?
I just bought the 800 pound jack last week and it is a major pass, although I have only used it once. It looks a LOT sturdier than that 450 scissor jack. Something about that scissor jack setup just scares me! The 800 pound jack was on sale for 130 bucks. It made life so much easier than man handling the trans into place. The 800 pound one has tilt forward and back. Also it is very sturdy, we had the trans hanging off the front of the jack so the weight wasn't centered and the jack was still very sturdy.
I haven't used the 450 pound one but in my opinion the extra 50 bucks seems worth it for the nicer 800 pound jack.
well I might be removing the transmission in my subaru and the transmission weight is about 150 Lb's or so.
but the chains on the 800Lb one look weak
The chain is a joke, the chain and the way it hooks on. I just used a ratchet strap.
I bought one of these antenna wrenches last year to replace the power antenna on my old Delta 88. It looks like this. Cost $2.99.
View media item 8193
Major PASS. Easily removed the antenna nut that had been on there for over 20 years.
Link for this? I can't find it on the site...
I'm going to give it a try.. is HF still doing the 20% off?
I think you would have to argue that it isn't technically a floor jack, it's a transmission jack.
http://www.harborfreight.com/1-2-half-inch-electric-impact-wrench-45252.html
PASS.Made my life so much easier, I am not sure how well this would work on heavy rusted lugs, but it works great for me.
Does anyone know how Harbor Freight will honor a warranty when it comes to their trailers? I have had my trailer for two weeks now about and it has worked out nice, BUT.... last night I loaded the heavy duty trailer with approximately 1,500 lbs of lumber, cruised at around 55 MAX and blew a tire.
It looks like the fenders (the arm that holds the tire fender covers on), struck the tire and caused it to fail... the one fender is bent where it hit the tire and the other one rubbed so much that it removed a thin layer of rubber from the other tire.
When I built the trailer the arm bracket looked very close and they bounce a ton... I was wondering if this would be an issue but it did not look like it could really strike... little did I know that if you add a good weight on the trailer it pushes just enough to strike when it shakes.
Not looking to return the trailer, just want the tires replaced since they are destroyed. IMO it's a flaw in their design. I will probably have to make my own brackets because I can not trust those from HF.
With that said, I will give the trailer a FAIL due to the flaw in design.
You have a 30 day customer satisfaction and 90 warranty exchange on any item we sell as long as you have your receipt. Most stores want the whole thing back when there is a problem. Call your local store and ask what you need to do. IMHO, take the trailer back and get your money. Sounds like you are unsatisfied and still will be later on.
He offered to do the whole trailer but in general I am happy with my purchase. I will bend the fender brackets this time so that they stay far away from those wheels and keep an eye on them and would recommend anyone else with this trailer to do the same.
I talked to the manager and he said just to bring the wheels back and they will replace both of themHe offered to do the whole trailer but in general I am happy with my purchase.
This was a MAJOR FAIL for me.......and at about half the distance of yours. Also don't like the white color of these.Driveway Alert: PASS
I have the transmitter on a fence post 250' away from the receiver, which is mounted in the kitchen. I'm using an old wall-hanger transformer to power the receiver.
It works great, I'm alerted to EVERYTHING that moves across it's path. I'm surprised there's so much critter activity in the driveway!
The ones I found on the shelf had been used by somebody and they returned them. The crack sales team at HF just threw the failed tools back on the shelf for sale. This was definitely not a manufacturing error, these failed while in use[/QUOTE
Someone was probably replacing a clutch on a BMW.
That looks like someone used it on a smaller bolt than that size socket, its only rounded the inner lobes, which makes me think it is human error, not bad manufacturing.
TheGrooveking
Item# 42211 - Car Garage:Great looking portable garage. Supposed to be UV protected, yet just after a year the tarp covering has become brittle and tearing, along with just six months of being setup the thread holding in the door zipper started to unravel. Being that I purchased two of these and assembled them as one long garage, with both failing in the above manner lets me think others will have issues as well.
FAIL
I have used other brands of these portable garages and most last at the minimum of 4 years before the tarps needed to be replaced.
NOTE: If they don't ask you to buy an extended warranty on a product, be leary of the product.......this might mean they had so many claims, they no longer offer extended warranty, just trying to read between the lines.
1500lb tire dollies http://www.harborfreight.com/automo...e-1500-lb-capacity-vehicle-dollies-67338.html
fail. while spinning my landcruiser (body/frame/axles/tires only, no powertrain), the tires slid off the dollys twice, then hit a crack and one of the casters folded the corner of the tray
