1SlowFormula
I am getting ready to not only fully re-wire the house (built in 1915 + 3 major renovations over the years) but also install a sub panel for the detached garage built in 1980. The issues the property has electrically are crazy, it has good new run from the street to the 200a box then from there it goes downhill fast. Things like:
1 12-3 line with the red connected to a 15a breaker and the black to another 15a breaker and the neutral to the neutral bar and the ground to the ground bar (those last to as expected), this runs through an older metal conduit back outside the building and along the foundation (not buried) to the front of the house then up the wall to the original 1915 fuse box that has been gutted and turned into a junction box. From that junction box those 2 power circuits get joined to 2 separate hot knob and tube lines and the neutral knob and tube lines join to the single neutral and the box is then grounded. Those 2 knob and tube circuits run 50% of the upstairs lights and outlets, illegally spliced (someone cut the sheathing and just wrapped the romex onto it then just threw a little electrical tape around that) with romex, and random outlets and lights in 3 rooms on the first floor some with romex at the boxes so there must be more illegal splices somewhere.
I have run electric many times before but mainly as a laborer where someone else figured out the circuit layout. I am a software engineer by trade so I have the ability to figure it out, I just never had the chance before, so my questions might sound basic in the beginning, but it will be well thought out before applying it to the house.
Anyhow that was just background and not the full purpose of the thread. Here are a few of my questions:
I want to take the 1 15a circuit I currently have running out to the garage and put in a sub panel, in consulting a local electrician he said all I needed was a 100a sub panel. But the question is if I take 100a away from the 200a in the house does that only leave 100a for the house, or is it a subset that isn't really calculated from the main house panel?
When laying out the circuits in the garage, before actually buying the tools/appliances how can I accurately calculate the load? Is there a general rule of thumb that x tool/appliance needs y size circuit?
Here are the list of tools I own and a list of tools I will get in the future, how do I figure out the circuit load or do I just run the circuits for what I have then run the others once I buy the tools?
Own:
-- 120v 1.5hp 33gal air compressor (will probably have a dedicated run since it pops the breaker now if anything other than a radio is running at the same time, lol)
-- 120v 20a welder (same as the compressor, it will probably have a dedicated line, but doesn’t pop the breakers now like the compressor does)
-- 120v 6hp 16gal shop vac
-- 120v 1/2hp bench grinder
-- 3/4hp drill press that could be wired 120 or 240, currently wired 120
-- misc wood working tools (table saw, 2 routers (1 table and one hand held), small planer, compound miter saw, and a few misc sanders) more than likely only a couple would ever be running at one time and even if I did have a helper it would be one person cutting while one was sanding so the load there shouldn't be that bad.
-- Small refreshment fridge
-- 2 garage door openers
On the 'wish' list:
-- good 240v mig welder
-- good 240v tig welder
-- good plasma cutter, probably 240v
-- better air compressor, probably 240v
I figured there would only be (2) 240v circuits for the wish list stuff, one for the compressor and one for either the welders or plasma cutter to be plugged into as needed/used.
That doesn't count standard lighting and outlets (well kind of counts outlets since most need to be plugged in, lol) and the electrician said a 100a panel should handle all that. I know the 240v items need separate dedicated runs, but how should I calculate the runs for the other tools and should I assume that they would never really be running at the same time or calculate it like a house that it should be calculated as if all were running at the same time even if they are not permanently plugged in?
Own:
On the 'wish' list:
