ZRX61
It's very close to RAF Moss Green as used in Spitfire/Hurricane cockpits etcI like that green -- looks like MG TC engine green....
But it's actually Rustoleum Spruce Green from Lowes......
It's very close to RAF Moss Green as used in Spitfire/Hurricane cockpits etc.
Hmm. Wonder if MG were using surplus Spitfire paint? ;-)
WWII aircraft were built at Cowley & Longbridge....& just about every other UK car factory... I've noticed the interior of some USAF C17's is the same color...
Insides were either moss green or black... or more often a combo of bothYou made me curious so I had a look -- MG built a number of things during the war, but the largest was the front section of Albermarle bombers. Wonder what color they were...
Well things didn't quite go according to plan....
...yes, I did pick up the Prentiss 52...
bought this vise today, wilton 1760. pretty excited about it. looks to be made in 1993, is that to new to be any good? what changed from the older ones?
That's quite an offset but still a great vise.The parts are not directly interchangable as you can see.
Here is a Wilton corner-mount vise.
I'd be interested to know any information about this model, including the proper name for this style of vise, the Wilton model number, dates of production and original cost.
My newly acquired REED
View media item 9251
EDIT:
Any one know why the one jaw lookes like it could slide off?
EDIT:
Craig, thanks for posting the pictures.It should spin around to about 90 degrees ...
I think you need some pipe jaws for that nice Wilton!
Indeed I do - no idea where to get them from, however???
But the extra space under the jaws may come handy, too. That's probably why someone removed them in the past.They aren't cheap, about $80 for the pair
It is for grabbing tapered workpieces. That is a really nice vise!![]()
Dieseldent - that is a swivel jaw vise and it is much groovy! Basically you would pull out that pin and the rear jaw would pivot to match the taper of a workpiece that did not have parallel sides. Put the pin back in and it was locked into a parallel jaw vise like most vises. The problem happens when the jaw is not used much to pivot and rust will sort of bind it up in a fixed position. Pivoting will look like this with the pin removed:
View media item 8909
See the groove in the jaw? This is where the locking pin runs across locking my jaw in place. If yours is like a Prentiss (and I think it is...) then just pivot yours around 90 degrees and it will move forward (towards the other jaw face) and come out.
Craig
View media item 8897
My static jaw looks like this on my Parker with the jaw removed:
View media item 8899
If yours is like a Prentiss vise, then you can not remove the jaw until you pivot it almost 90 degrees to the side and then it will pull out forward. It locks into place by the main pivot jaw having an "undercut overlap". On my Parker, there is a cross pin that you punch out from one side to the other side completely. This allows the jaw to just come straight up and out from any position.
If you clamp your Reed (with everything taken off of it) in another vise and hit (smack, tap, whatever makes you comfortable) the tail end of the swivel jaw (I use a wooden stake between tail and hammer, short PVC pipe piece works a treat) it should start to swivel.
View media item 9260
It should spin around to about 90 degrees and you can just push it out the end of the main piece.
View media item 9261
Best of luck and start a thread when you start taking it apart so we can see what you have in the photo backgrounds. LOL
Craig
Most excellent! A cyber pat on the back to both you and Robert for coming up with such a great Wilton. However, the limit is one American vise per Canadian household so you are hereby finished.....unless you bring back some Jos Louis Snack Cakes.
Craig
Great vises but... both of them should be mounted closer to the edge of the bench, so they could hold a broomstick in vertical position.here's a couple from the shop ... we got about 3-4 more, I'll post them up monday evening...
[The date stamped on it is 173 so I'm guessing it was made in Jan 1973. Not too shabby for a 38 year old vise!!
That 101028 was one of the nicest 4" bullets Wilton ever made. That vise was previously their 9400 which came around in the 50's. Really no improvements on it from the late 50's to their last year of production in 1974. Don't use the anvil and with some luck, you might find a swivel base one day. That is my favorate bullet!
was wondering about the anvil. I wasn't planning on wailing on it but I'm thinking with extended use, there'd be some risk of cracking the body of the vise as it seems a little thin and awkwardly placed. I'm planning on picking up a small anvil in the near future anyways so I'll just pound on that instead of the one on the Wilton!
Been looking around for swivel bases with no luck but plan on contacting Wilton and Ackland-Grainger when I get a free minute to see if they can find something that would work.
The swivel base from their current 400S will work but then they arn't cheap either. Wilton sells it as a complete assembly, base, inner ring, bolts, and swivel handles. 2904120 part # and it goes anywhere from $75-$100.
thanks for the info!! was expecting to pay upwards of $100 for it so I wasn't far off at all. i have it set up the way it is at the moment and so far I'm very happy with it. The design initself pretty much removes any chance of "play" in the dynamic jaw which was the thing I didn't like about the cheap chinese vise i had been using up until now.
now I know why a lot of people rave about these old Wiltons!
Welcome a Yost 203 1/2 to my workbench.
