central1ny
- Joined
- Feb 22, 2009
- Messages
- 134
I am installing a new 200A meter socket and breaker panel and need help on how to run the grounding electrode conductor. I am using 4AWG stranded copper and (2) 8 foot, 5/8" copper grounding rods installed 6 feet apart.
My original plan was to just run a single conductor from the breaker panel to the first electrode clamp and then continue this to the 2nd electrode. But then the electrical guy at home depot said that I need to create a loop and double up the conductor. I am not sure which is correct. My existing meter has 2 cables coming up out of the ground and running to the breaker panel.
Should I run the single wire or is there an NEC code that requires doubling the wire? I already paid the $60 for the wire so I might as well use it if that is standard practice (don't think I can return the wire). If I do create a loop with the wire, looks like I need two clamps on each grounding rod per NEC 250.70?
