Farmallgray
This is my first post here. I found this site a few weeks ago and it looks like there is lots of good info here.
I collect and restore antique farm and garden tractors. I built a 50'X72' building for storage and workshop space about 6 years ago. This is an ongoing (as the budget allows) project. 2 years ago I ran 200A electric service to it and this fall I concreted 1/3 of it (24'X50') to be my workshop. I put pex tubing in the concrete for radiant heat.
My next step is to start insulating and sheeting the work shop area and building a partition between it and the storage section. I'm including a pic from when we poured the concrete. You can see how the girts and purlins are layed out in the pic. It is a web truss building similar to miracle truss brand. It uses horizontal 2x6 girts and verticle 2x6 purlins all on 2' centers. So I have 5-1/2" of space for insulation. My initial plan was to use 6" fiberglass bats or rolls in the walls (sheeting with OSB) and that plus 1" foil faced foam board in the ceiling. That would give me R19 for walls and R26 for the ceiling. That is a liitle light for a house, but should be satisfactory for a shop. I am open to other suggestions for insulation. I'm wondering is I should use insulation with the paper facing, and should it be toward the inside of the building? I'm concerned about condensation behind the isulation. I'm also wondering if I should look into the foil/bubble insulation either instead of or in addition to the fiberglass. Sorry for such a long post.
