I built my 65' x 38' shop on the slab foundation of what was my old house and shop, which was destroyed in a tornado in May 2003. The house and shop were of block construction. The area that separated my home and shop was concrete blocks, and are now part of the working floor area of the shop. Problem is, it is NOT a smooth transition point! I had filled the holes in the block with Quickrete in '03, and it has stayed relatively smooth. But, now the filler is crumbling, and using a creeper or floor jack in those areas is nearly impossible.
Should I bust out all of the remaining block that is in the floor (where the walls used to be) and simply have concrete poured in to replace them? That would seem the easiest solution, but I'm open to ideas.
