hazardous?
B bchee Well-known member Joined Aug 20, 2007 Messages 6,148 Location Texas May 9, 2011 #1 hazardous? Attachments wire.jpg 6.3 KB · Views: 39 Last edited: Mar 26, 2025
F Falcon67 Well-known member Joined Jun 11, 2009 Messages 18,371 Location Merkel, TX May 9, 2011 #3 It's how you string 2-3-4-x switches together in a box with a common hot.
OP B bchee Well-known member Joined Aug 20, 2007 Messages 6,148 Location Texas May 9, 2011 #4 thanks Last edited: Mar 26, 2025
Z Zeke Well-known member Joined Aug 13, 2009 Messages 17,176 Location Long Beach CA, the sewer by the sea. May 9, 2011 #5 Actually, a little bit of talent is required to do this nicely. I always appreciate someone who makes up boxes neatly.
I ibedayank Well-known member Joined Feb 2, 2011 Messages 2,619 Location Columbia TN May 9, 2011 #6 or mulitple outlets
OP B bchee Well-known member Joined Aug 20, 2007 Messages 6,148 Location Texas May 9, 2011 #7 Does it have a name? Last edited: Mar 26, 2025
F Falcon67 Well-known member Joined Jun 11, 2009 Messages 18,371 Location Merkel, TX May 10, 2011 #8 I was going to go with "wire *******" but it just sounds wrong.
R rburke65 Well-known member Joined Nov 10, 2007 Messages 12,349 Location Canfield, Ohio May 10, 2011 #9 I re-wired old houses for 11 years and this connection as no name or term as far as I know.
1 1Garageman Well-known member Joined May 12, 2009 Messages 4,417 Location Columbus, Ohio May 10, 2011 #10 Falcon67 said: I was going to go with "wire *******" but it just sounds wrong. Click to expand... WOW, that's a new term in electrical wiring for me
M May Pop Well-known member Joined Aug 7, 2005 Messages 783 Location Lake in the hills Il. May 10, 2011 #11 Its called 'looping'
T theoldwizard1 Well-known member Joined Feb 22, 2011 Messages 43,498 Location SE MI May 10, 2011 #12 I am not an electrician (although I "play one" at times). I have seen that a couple of times in older houses (+30 years). Every time it was the "perfect solution" to a tight situation !
