Inside Window Question
Ezzie
Lake Chapala, Jalisco
I'm getting ready to frame the interior walls for my new shop and want to put some windows in between the wash bay area and the office/lounge. I am looking for ideas for framing in some non-operating windows (single pane, double pane thermal??). The building will have radiant floor heating but could see an air temperature differential of 25-30 degrees F. Are there certain standard sizes available such as 3' x 4' or something??
timgr
Medford, MA USA
Yes, there are standard windows. The cheapest will be what they have in stock at the big box stores. I replaced the tiny fixed window in my garage with a Pella 3'x4' slider from Lowes for ca $125 IIRC. Not sure they'll have big fixed windows in stock, but you should be able to buy any standard window with a couple weeks lead time. Fixed windows should be the cheapest style.
E
Ezzie
Thanks timgr - I'll check at the local HD or Lowes for standard sizes. I don't need any frames or anything, I'm just after the glass. The wall framing will be the window frame - just planning on lining the outside (wet side) with some puckboard and caulking then using some quarter round molding on the inside to hold the glass in place.
trovato
Putnam Valley, New York
If you are really looking for just glass, without any frame of any type, you're not really looking to buy a window. I think in that case you need to find a local glass supply house. For single pane, they'll just cut you a piece any size you want. If you want you can also use a piece of plastic, which you will find available at your local HD.
kbs2244
That same local glass shop may have some measureing mistake double panes lying in a back corner.
They have to buy them and bad specs happen a lot.
E
Ezzie
Excellent suggestion!!! I called a local glass shop and indeed, they do have double glazed sealed units that are leftovers from a major job they recently did - some sort of retail store chain job they had. They want to unload them for 1/2 price (about $150 ea. for 4' x 5' tinted units).
boiler7904
NW IN
I'd get a frame for them, preferably not wood. The splashing water in a wash bay will rot a wood frame that isn't probably caulked, painted, and maintained. Using the wall framing is a bad idea for the same reason. I'd see if your glass shop has whole (frame and glazing) units that you can get cheap.
E
Ezzie
I'm thinking of lining the walls of the wash bay with 4' x 8' sheets of 1/4" puckboard and using cutoff strips to do the window sills and caulking to seal where it meets the glass. "Puckboard" is HDPE (high-density polyethelyne) sheeting commonly used in ice hockey arenas, pig barns, horse stalls, etc. - tough stuff but expensive - about $70/sheet.
http://www.systemfence.com/pages/catalogue/barn_solutions/FRP - Puckboard.pdf
boiler7904
NW IN
Looks interesting. Leave it to a Canadian to line their garage with the same stuff they use in ice hockey rinks.:)
