RaceDeck - How easy to cut?
Sgpbike
I have a two car garage and have two round support poles in the center of the garage. How do I trim the RaceDeck around the base of the poles when they fall in the middle of the RaceDeck square? I am not sure how to accurately measure the cut?
RaceDeck1
Salt Lake City , Utah
Hi
Without seeing what exactly you are doing it is hard to give you the best way, if you send us a picture, we will tell you exactly what to do.
From what you described. you have two choices. Use a hole saw to cut out where your pole will be on the tile> then take a jigsaw and cut a straight line back to the hole you cut ( this way you can spread apart to slide into place...) if your hole saw does not create a big enough hole, you can use the jigsaw to make it the exact size you like.
Again, call us and we can walk you through it.
Sgpbike
So how did your install go?
I am still in the planning phase. I am working on some patterns now. I am not handy with tools and do not own a hole cutter or jig saw. I guess i will have to learn. My problem was trying to figure out hoe to install with the two poles in the center of my garage.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
THis is on a rubber and foam product but gives you the basics on how to mark out
Another way that may give you a little insight
