Harbor Freight Sand Blast Cabinet - Light Upgrade
shocksystems
Ipswich, MA USA
I know several members have mentioned upgrading the light on their Harbor Freight blast cabinet to better illuminate the inside of the cabinet.
What are people replacing theirs with? It looks like the light in there now is 2 20W fluorescent tubes.
Before I go looking for something I thought I would ask what has worked for others.
Cheers!
Jim
PCO6
Newmarket, Ontario
My cabinet isn't a HF (it's home made) and I've tried various types of lighting in it. I seem to have had the best luck with a pair of inexpensive halogen spot lights mounted high in each corner.
Jeff Ivers
Oklahoma
Man, that is one nice looking cabinet! Well done!
PCO6
Newmarket, Ontario
Thanks Jeff. It's about 30 years old. I've made some modifications to it over the years and would like to build another one based on what I have learned. A deeper hopper would be the main thing. I set it up for both pressure and syphon feed blasting. The vacume system works well - inexpensive Sop-Vac with a home made water based filter. The lack of gloves in the door probably looks odd. I have long gauntlet gloves that I wear and simply put my arms through the holes. They seal well and it allows me to pass small parts through without opening the door. It's seen a lot of use over the years. :thumbup:
FORMUD
Clayton, Delaware
I know digging this up from the past, but I found this while searching lighting ideas........Could you post up some more info on the "Water based filter" For me?
PelicanPines
The water based filter is the white bucket with black lid with two hoses on top.
The hose from the box to the bucket is long (into the bucket)... the hose from the bucket to the vac is SHORT into the bucket. Water is about 1/2 way up the bucket... submerging the long hose but not the vac (short) hose. When dust particles go thru that system.. they get trapped in the water.
I have one I purchased a long time ago to do dry wall sanding. Couldn't find a link to one... on a quick search.
PCO6
Newmarket, Ontario
FORMUD - Here are a few threads that provide some pictures and an explanation along with some other links. With mine, I use 3" or 4" of water in the white pail and neither hose is below the water level. I understand some others do it differently. I purchased the 2 port plastic lid at Busy Bee Tools but they are pretty easy to make.
Mine creates a cyclone effect above the water line and the sand being heavier than air falls into the water. I use a small 5.5 amp, 4 gallon Shop-Vac without a bag and cabinet is very dust free.
Hope this helps.
http://garagejournal.com/forum/showthread.php?t=159702&highlight=sandblast+water+dust+control
http://garagejournal.com/forum/showthread.php?t=75708&highlight=sandblast+dust&showall=1
FORMUD
Clayton, Delaware
Hope this helps.
Thanks for the info. Now I know what to get. I'll see if I can't find a plastic or metal container with a clamp style lid for easy removal.
I stole your halogen work light set up. Only tried one 150watt light, Definitely going need one coming from the side too.
