I think the floats and choke bit is quite amusing
Honest to god, my junk homeowners manual says this. I know for sure on a carburetor those could be legit. I'm not sure if you guys have haynes in england or I mean something similar.
How many miles has the car done?
How long have the German spark plugs been in the engine?
190,000. 20,000.
Dear god put some plugs in it, then check connection at the mass air flow. and FP.
It is speed-density.
Here's what I would do:
1) I would find out the code definitions and check underhood for obvious problems;
2) I would search the car forums online for my particular car to see if there are any obvious problems on that model and with that code;
3) I would be pretty limited now because I have no live data or fuel trims but with symptomatic diagnosis? you can take a few cracks at likely issues;
4) I would also work through the factory manual; not some **** like Haynes.
If all this failed I would take it to the Benz dealer and tell them to scope the cam sensor and run Star Mark on it and tell me what is wrong. $100 dollars is money well spent if you don't have the equipment.
I'm afraid on this one you need to scope the cam sensor to be sure it is a problem.
My uncle Joe said my Bosch plugs were causing misfire; Mercedes don't like Bosch plugs. On seond thought this is probably it. Bosch plugs.
I like this somewhat. Unfortunately, why would I pay $150 for the manual/power train books, if I am only willing to spend $50-$70 for a no-frills autozone type pocket reader?
I like the online search but it has some problems, like suggestions to replace all kinds of parts, I have already spent more than a nicer scan tool would have cost. Granted, even that alone might not get me where I need to be.
Are you suggesting I take any make/model to MB because their scope is better?
LOL on power probing the CAN link!
Again, I believe I see what diesel research is getting at. The responses have been somewhat insightful, but I think most of you might be on the wrong track.
Personally, I'd charge the battery and once that's done have it checked out, and run a charging system test on it (check for A/C ripple, proper voltage output, etc). I'd take care of that before I worry about any codes, wrong plugs, etc.
This is a GREAT suggestion, but you should explain why? and if you would do this with every car or only certain symptoms or codes?
In REAL LIFE the above actually was a problem once. Cranks-No start. Cranking voltage about 10.7 volts. Starter motor spinning over healthy. Advanced symptoms were weak spark. I wasn't there in person, I was talking my brother over the phone. He observed weak orange spark with the home owner type spark tester.
A lot of head scratching to figure out troubleshooting methods since he had no codes to work off of, and no diagnostic tools.
Told him to put the battery on a charger since he ran it down trying to crank so long. He calls back and told me the prob was fixed and runs like a champ.
What happened? Battery charger began to charge, quickly showed charge, but then dropped back and refused to charge. A load tester had showed damaged cells. Well doesn't say damaged cell, but with the reduced voltage and cca it is safe to assume. Found out later there was enough voltage to fire starter, but system depends on a very healthy battery in order to produce proper spark under compression.
_______________________________
That said, a batt won't fix everyones problems, so I am still looking for these so called DIY trouble shooting techniques.
There are still a few things left I could do easily and they are not model specific, they pertain to all hall effect/distributor type vehicles.
