How do you have stuff organized in your chest? (top to bottom)
l_bilyk
Ontario, Canada
This is how I have it right now (mine is a 26" wide so only 1 row)
box
top - impact sockets, 3/8 12 points, flex sockets, favorite ratchet
empty drawer except for an o-ring kit, i think my torx bits and hex and all that stuff will go in here
steering wheels pullers, spreaders, inside bore gauge, calipers
screwdrivers, nut drivers
cutting pliers: end nippers, tin snips, side cutters
clamping pliers: channelocks, adjustable plers, vice grips
bottom - drive tools: ratchets, extensions, speeder handles, breaker bars, t-handles, etc.
rollcab
top - 6 hansen trays with most of my sokets, spark plug sockets, a few odds and ends
junk drawer: light bulbs, fittings, roloc disks, couplers, chisels, stethoscope, circuit tester + more junk
air tools
wrenches
bottom two - grinders, sanders, big 3-sided pullers, cordless drill, grease guns
should i move anything? ideally i would like to have all my sockets on the top, but all the hansen trays don't fit :sad:
eschoendorff
Ya know, it's really hard to answer a question like this because so much is personal preference. It also depends so much on what you spend your time doing (ie: if you were working on farm equipment or something, you would probably want your 1/2" drive stuff closer than your 3/8" stuff).
My own .02...
Start with what you have, and then move things around as needs change. As long as you know that you have the right tools and where they are located at any given time, you should be 75% of the way there. Label your drawers. I know it sounds cheesey, but it has helped me a little.
Once again, just my .02.
Ed
L
l_bilyk
Ontario, Canada
Yeah i'm not totally happy with it... i would like to keep all my chrome sockets on top but they just don't fit because of the little dividers welded to the box
I was thinking of cutting them down, but don't want to butcher the box
bmwpower
Drawer 1 (3 partitions):
1/2" Metric sockets/ratchets
3/8" Metric sockets/ratchets
1/4" Metric sockets/ratchets
Drawer 2:
Metric wrenches
Drawer 3:
SAE wrenches/sockets
Drawer 4:
Screwdrivers/nutdrivers
Drawer 5:
Pliers
Drawer 6:
Hammers
allen keys
files
Drawer 7:
Special tools
Torque wrench
Soldering stuff
Meter
Drawer 8:
Goggles
Tape
Misc tubing
Spring compressor
etc
Southern Europe
Nice way to show off, eh?
I have 2 top boxes and 2 roll cabs
TOP BOX 1
Drawer 1
Miniture screw drivers
Air pressure gauges
Pick up tools
Tape measures
Drawer 2
Metric nut drivers
Rivit gun
Valve Lapping tool
Drawer 3
Tap and die set
Tin snips
Knives
Bottom Box
Drawer 1
Teflon tape
Electrical tape
JB Weld
Glue
Silicone gasket maker
Drawer 2
Files
Drawer 3
Carbide burs
Plastigauge
Screw extractors
Reading glasses
Drawer 4
Drill bits
Drawer 5
Channel lock pliers
Ring pliers
Stork needle nose pliers
Oil filter wrench
Drawer 6
Vice grips
Common pliers
Wire strippers
Radiator hose pliers
Drawer 7
Chisels
Punches
Adjustable wrenches
Pickle fork
Ball joint seperater
Lady feet pry bars
Pry bars
Scrappers
Cotter pin puller
Scribbers
Drawer 8
Ratchets
Extensions
Speed handles
Drawer 9
Micrometers in mm
Feeler gauges
Torque wreches
Caliper gauge
Drawer 10
Air tools (ratchets, impact gun, drill, die grinder, chisel)
Oil pump primer
Dial indicator
Crankshaft socket
Magnetic bridge
Drawer 11
Timing light
Radiator hose tools
Clutch alignment tools
Drawer 12
Coil spring compressors
Piston ring compressor
Piston ring installation pliers
Cam installation handle
Carb stand
Piston ring filer
Second Top Box
Drawer 1
Hose pinch pliers
Drawer 2
Spark testers
Gasket punches
Spark plug wire pullers
Drawer 3
Allen keys
Drawer 4
Older timing lights
Remote starter
Drawer 5
Compression gauges
Oil pressure gauge
Drawer 6
Multi meter
Drawer 7
Number punches
Letter punches
Air hose adaptors
Air pressure gauges
Drawer 8
Tubbing benders
Tubbing cutters
Drawer 9
Circut testors
Door trim tools
Drawer 10
Screwdrivers
Drawer 11
Metric combination wrenches
Metric line wrenches
Metric midget wrenches
Metric gear wrenches
Metric ignition wrenches
Drawer 12
SAE combination wrenches
SAE line wrenches
SAE midget wrenches
SAE gear wrenches
Distributor wrench
Second Roll Cab
Drawer 1
Hand sockets in all 3 drives
Torx sockets in male and female
Phillips sockets
Drawer 2
Impact sockets in 1/2" drive (Metric and SAE)
Swival sockets in 3/8" drive (Metric and SAE)
Battery terminal brushes
Drawer 3
Cooling system tester
Harmonic balancer installation/ puller tool
Spindle dies
Drawer 4
Brake tools
Brake caliper tools
Brake bleeder tools
Drawer 5
Micrometers in SAE
Gear pullers
Heat gun
Soldering iron
Wire wheels
mikeyr
Santa Barbara, CA
In the order of what I use the most.
1st. drawer BSF and Witworth
2nd. drawer, metric, 3/8's and 1/2'
3rd. drawer, screwdrivers and pliers
4th. drawer misc tools
5th. drawer SAE tools (hardly ever use them)
6th. drawer, torque wrenches, timing light, VOM
second box, all the other just like pullers, brake tools, welding stuff, junk that is to bulky to go in drawers under workbench.
Tim240Z
LAX area, So Cal
No real method to what I put where, only that I put the heavier stuff as low down as possible so that the tool box isn't top heavy...makes it easier to roll around and less likely to fall over in an earthquake.
SuperKid
Indiana
Organize your chest? BWAHAHAHAHA! Is this some sort of joke? J/K! I havn't really gotten around to organizing my tools yet. I still need to buy a larger box and some more tools. Then I'll organize them.
ampegor
ontario canada
Top of box 3/8 1/2 3/4 sockets. shallow/ deep/ impact / special etc
top left drawer 1/2 and 3/8 drive ratchets and extensions
Top right drawer all wrenches under 1" and 24 mm
second left screwdivers
second right pliers (all types)
third left 1/4 drive sockets and ratchets etc. standard and metric hex keys
third right misc stuff, scrapers, mirrors, magnets, knives, feeler guages etc
fourth left pipe wrenches and adjustables
fourth right prybars, punches etc
fifth left hammers
fifth right air tools
thats just my top box.
thye bottom box and the two wall cabinets are full too but not strictly organized
Andy
OctaneMotorsports
Caledonia, Ontario, Canada.
Top: Sockets. Deep drive, 1/4", 3/8", 1/2". Standard drive, 1/4", 3/8", 1/2".
Top left drawer: Timing equipment. AIM Multichron stopwatch, notepad, pens, etc.
Top middle drawer: Wallet, keys, phone, etc.
Top right drawer: Spare hardware, etc.
First drawer: Ratchets, extensions, speed handle, nut drivers, etc.
Second drawer: Wrenches. Metric and SAE. Standard, stubby, ratcheting etc.
Third drawer: Hex. T-handles, L-keys, hex sockets.
Fourth drawer: Screwdrivers. Standard, stubby, ratcheting, offset, prescision.
Fifth drawer: Pliers, pressure guage, hammer, mallet, cable luber, chain breaker and other karting specific, etc.
Bottom box:
First drawer: All my pneumatic tools.
Second: All my electric hand power tools.
Storage space: Fluids, chemicals, cleaners, etc.
stimpy
troy twshp IL
Hmmm , top of box ( lid area ) Mt trashmore , anything like booklets and gloves and parts that haven't found a home yet goes up there ,
Top Drawer : 1/4 inch drives, sockets and tool bits and electric 1/4 inch rachet
2nd drawer : 3/8 drives, and extensions and universals
3rd drawer , left side 3/8 metric 6&12 pt shallows , right side 6&12pt American Std.
front of drawer deep metric and Amer.stand. 6 &12Pts
4th drawer : left 6pt comb wrenches American standard , right 12pt comb wrench
front of drawer offset boxes A.S., along left side Lifter wrenches ,
along right side fuel pump wrench and hydraulic wrenches
5th drawer : metric wrenches set up as above and backup wrenches
6th drawer : screwdrivers too many to try to sort so hog pog.
upper right drawer: junk drawer ( lenses for welding , safety wire ,
pens , pencils , razorblades and carpet knives)
URD #2 : pliers , visegrips , channellocks , linemans pliers
URD #3 :HEX Key Sets, Torx Key sets , snap ring pliers
Middle Cab : Blue Knocker set , red rags , spring Hone , BFW ( 24 inch adjustable wrench )
Lower cabinet :
1st Drawer : 1/2 inch drives and sockets on rails, I barely use this drawer
2nd drawer: brake tools , line wrenches , flaring tools , special line tools ( ford fuel line removers)
3rd drawer: Pullers and hammers , chisels
4th drawer : saws and files
5th drawer : Air tools ( sold my compressor years ago haven't bought a new one.
6th drawer :impact sockets
7th drawer : electric die grinder , heatgun , electric wire and sheathing , zipties right drawers lower cabinet ( RDLC for short )
RDLC 1 : more junk like little plastic containers filled with fastners , ear plugs ,
RDLC#2 : scrapers ,brushes, and picks and other devices to stab yourself with .
RDLC#3 : oil filter wrenches
RDLC#4 : pipe wrenches and plumbing wrenches
RDLC #5: clamps
RDLC#6 : Rive guns and riv-nut tools
RDlC#7 : the big junk drawer ( air dryers, line oilers ,big pullers , extra drill bits in
coffee cans
side cabinet
drawer 1: safety wire tools
drawer 2: syringes
drawer 3: important papers ( snapon bills , owners manuals , porting templates ,
cubby hole top : VOM meters and analysers
cubbyhole bottom : extra welding wire spools , battery charger , extra cans of
safety wire ,
I am not going to list the other boxes as theres too much to list . :wtf:
RANDY SNYDER
Metro Atlanta
Man, I can't wait to really get started on this board and share my garage and projects. I'm right now putting together my tool chest. This is a great help. Thanks.
davestlouis
Lake St. Louis MO
I'm a lot like Stimpy, 1/4 drive sockets and ratchets on top, 3/8 in the next drawer, 1/2 below that, the rest I'm still playing with, just got a big Matco ProFormance rolling cab with too much room for what I have right now...it'll fill up, I'm sure of it.
Danglerb
SoCal
I have no sense over what should go where, but its slowly filling the box. Main trouble are all my screwdrivers and screwdriver type things.
I think I am hooked on the Mechanics Time Saver socket holders. The magnets have enough grip to hold it upside down, but easy release, and its obvious where stuff goes back. Only downside is the price since I want to try a couple styles, upright and sideways.
toolfreak
Illinois
The mechanic time savers are nice until they fall off what you're working on. It takes forever to find all the sockets and put them back into the holder.
caspian65
Typically, you will want the most frequently used to be the easiest to access. Put the frequent use tools in the drawers that require the least movement of your arms and body to access. Pretty simple ergonomics rules apply here. Of course, the size of the cabinet drawers will also dictate, largely, where tools are placed.
My top big drawer on my SO KRL1003 is filled with sockets and ratchets, which is what the drawer is designed for. The next drawer is screwdrivers, followed by pliers, followed by wrenches.
http://www.early-mustang.com/charles/tools/
TNToy
West Tennessee
The stuff you use most in the top, full-width, deep drawer.
Work your way down to stuff you rarely use, and bulky items like cases for compression testers, etc.
That lista cabinet is nice, but organized inefficiently: At least for a service tech, stuff I use a lot is 4 drawers down all the way at the back and it wastes a LOT spaces with those 'facom tool modules' - look at the pliers drawer, for example.
Where the heck are all the sockets?
