scott37300
How usefull is a battery load tester for a home mechanic? Is it pretty much just a go/no go test for a good battery, or is there other things you can do with it? Would a HF 100 amp tester work decent enough for a home mechanic or should I look at something else.
http://www.harborfreight.com/100-amp-6-volt-12-volt-battery-load-tester-90636.html
Or tooltopia has an OTC for 30 bucks if there is a difference in quality, http://www.tooltopia.com/otc-tools-3180.aspx
Or this one for 60 bucks, http://www.tooltopia.com/otc-tools-3182.aspx.
They also have this OTC for 130, http://www.tooltopia.com/otc-tools-3183.aspx. This looks to be just a voltage tester and not a load tester?
They also have carbon pile testers for around 90 bucks, http://www.tooltopia.com/electronic-specialties-710.aspx. Is there anything special about these pile testers that I should get one of these instead of the standard load tester?
Anything else about battery testers I should know?
