new shop stain, seal, or do nothing
tankwilson
Iowa
Hey guys finishing up my new 32x30 shop. Will b used as a fab shop. Welding, oil changes, car building and harley. I have old steel up on the walls and the whole shop has a vintage feel.
What should I do to my new concrete floor? Stain, seal, or nothing? It will see a lot of abuse.
Thanks
Matt Wilson
Beaumont67
St. Thomas, Ontario
Nothing, except if you paint a few cars in there, from time to time...the overspray on the floor, can look cool / vintage.
Beaumont { :>)) www.petperfectexpress.com
1965 Malibu S/S, 1966 Beaumont Custom original paint, 1967 Beaumont Custom, 1967 Beaumont Custom original paint, 1967 Beaumont 396-350HP Sport Deluxe M21-411's - SOLD 1970 Judge
Edger
Melbourne Australia
Use a concrete hardener/densifier preferably lithium based. It will repel most wet spills and make all clean up much easier. It will harden the floor to resist chipping and wear, look natural and cost way less than a coating. Best of all it is permanent and if you ever want to paint it later it will be easier to prep and grind.
T
tankwilson
Iowa
Thanks guys... Heres my deliema.
Do nothing and i will have oil stains
Sealer or Epoxy and will have to worry bout welding and recoating
Is there something that will seal it up well enough to wipe up oil and gas and look like nothing. Like a flat or semi gloss sealer?
What's the difference between a sealer and a densifier??
thanks
matt
LegacyIndustrial
deerfield, IL
Your dilemma is everyone's dilemma.
Densifier is a penetrating product, will not even look like it's there.
Sealers are typically topical (on top).
We have a matte gloss sealer, used in retail quite a bit.
http://legacyindustrial.net/cart/epoxy-coating-hd015-1-gal-p-235.html
or we have a densifier with a waterproofing agent built in:
http://legacyindustrial.net/cart/densifier-and-waterproofer-1-gal-p-117.html
Densifiers will not keep the concrete from staining. However, over time a burnish will appear as a side effect of your foot and vehicle traffic. Later it will become a little more resistant to staining as this burnish occurs.
vonhef
Southern, Ok
I ordered 5 gallon of this densifier with water proofer a few weeks back. Will be applying within the next few weeks. I wanted something that was welder proof, so a topical application was not an option.
I really do like the look of a an epoxy floor... just wouldn't last in my shop.
RTcat
South Central Wi
Please post pic's if possible after you apply! Any thoughts on what you expect to happen color-wise to the floor?
Edger
Melbourne Australia
thanks
matt
Densifiers semi seal the surface so that it takes much longer for the oil to stain the concrete, also it is much easier to clean the oil off totally. There is no guarantee I know of to say it will not stain, ever. See http://www.situp.com.au/Concrete garage floor coating.html for explanations about different coatings and the link at the bottom to hardeners. This is general information only, but it gives you a good comparison.
MDM
Florida
What about doing an acid etch stain for looks, and then the sealer to protect? If that works, what sealer would be best? I wouldnt think it shouldnt cost too much more to acid stain it first, and it would give it a cool look. I am just not experienced in the process but im sure someone is.
king nero
Belgium
If you don't do anything on the floor, won't you have enourmous amounts of dust continuously?
Will the densifier stop the concrete from giving dust? if it does, I'll bite and do the same to my garage...
I was giving a quote for polishing with quartz and cement after pouring... I don't know how that holds up after time, and about the dust problem...
darkk
Willimantic, Ct.
You could always mix your own sealer. 50/50 Linseed oil and mineral spirits. It can be applied with a bug sprayer, it lasts for 2-3 years before recoating. We used it in the *old days* in our garages. Just need to make sure no fire or sparks for the day til it dries, but I suppose that would apply to just about most coatings. Cheap and effective. Unless there is something intrinsically wrong with this solution, that's where I'm headed.
srode
Maybe you could epoxy most of it and leave one section without epoxy for welding and painting if you can hang a barrier to keep the paint in when spraying?
LegacyIndustrial
deerfield, IL
Tank, stick with one solution.
I like densifier for a real working mans garage, several to choose from.
Link: http://legacyindustrial.net/cart/concrete-densifier-c-22.html
If you want a good sealer with gloss go with our HD356voc, 2 coats.
You won't find a tougher sealer in a single component format. Excellent resistance against abrasion and common garage chemicals like gasoline.
Link: http://legacyindustrial.net/cart/hd356voc-urethane-sealer-1-gal-p-179.html
Of course, you can "densify" or "seal" your raw concrete or add some color with acid and non-acid stains beforehand. Link: http://legacyindustrial.net/cart/concrete-stains-dyes-color-c-27.html
We do have a stain sample kit to try...
http://legacyindustrial.net/cart/concrete-acid-stain-sample-kit-p-172.html
Good luck and feel free to call me if you need further advice.
Edger
Melbourne Australia
Concrete hardeners were first used to stop dusting and they do a great job. Now there are many types available and they are called densifiers due to the polishing industry using them.
Highly recommended to stop dusting.
T
tankwilson
Iowa
Thanks Scotty.
My garage is just under 1000 sq/ft. I will be ordering your densifier with waterproofing. How many gallon will i need and do you offer any type of online or "garage journal" discount.
Thanks
matt
LegacyIndustrial
deerfield, IL
Sorry Baz. We ship direct throughout the US, Canada and Mexico at this time.
We would love to make a relationship to establish distribution in the future.
