What have you learned by mistake?
Borrego
San Fernando Valley
Recently, I was cleaning out the drawers on a greasy and dirty tool box after I had removed many stickers on the outside. I decided to use some Goo Gone to remove the sticker residue. I accidentally got some of the Goo Gone on a heavily soiled interior part of the drawer. Had to wipe it off and found out it picks up grease and grime better than anything else I had ever used.
Maybe I wasn't smart enough to begin with, but I learned something recently by accident. How about you and your story?
strnjss
Boston Area
I've learned that pipe cutters are really really really sharp!
I'm in the habit of lightly running my thumb on blades just to make sure they're sharp before I use them for cutting (knives, scissors, utility blades, etc).
So when I bought a little pipe cutter wheel thing to cut some copper pipe, I did the same. I did it so lightly and didn't feel anything. I figured it was sharp.
Few minutes later, I was wondering where all that blood was coming from. The pipe cutter was so sharp, it cut my thumb open without me even feeling a thing!
I had no idea anything could be that sharp until that incident...
Catalyze
New Mexico
All sugar isn't created equal. Someone gave me a wine making kit one time in my younger days. I ran out of sugar while mixing things up so I added Powdered Sugar. I didn't know that it has corn starch. After much fermenting it was really really nasty smelling. I also learned to use a vise with a drill press. It was my first job out of the Navy and it was in a machine shop. I broke 2 fingers before I could get my hand out of the way of that Cincinnati Drill Press.
Craig
wafrederick
Holton,Mi
Watch where my fingers are,I cut myself with my Ryobi cordless circular saw once.My Snap On 3/8 air ratchets,watch where your hand is and youl will know right way.Slam your hand if not careful.Hoist arms too,I ran into them sometimes.Almost nailed myself with my finish nailer to a board,luckily it grazed my finger a little bit.Was not careful when using my skil saw once,cut the cord with the saw plugged in and luckily I did not get shocked.I now watch where the cord is.When I recieved my Fein multimaster,tried one blade against my skin shown on the infomercial while the tool was running.Went a little too far and cut myself.
znowaczyk
Oregon, Ohio...NorthCoast
Wasnt me, but I did witness it...When I worked at the VW shop, a loober goober hooked up the vag to a jetta...with an aftermarket stereo...So I guess I learned, VW fills their scanners with smoke!!
AZ_Catskinner
Morenci, AZ
I recently learned that a leather glove doesn't even slow down a 7" grinder with a Metabo cutoff wheel, and neither does your thumb.
mtkst19
blitzburgh pa
cloth straps for engine hoists can cut on aluminium cylinder heads. lost the tip of my ring finger finding that one out the hard way. had a engine going in the car, was starting the motor mount bolt by hand when the strap was cut by the aluminium head like a razor blade. freak deal, but lesson learned. chains only from now on.
bgott
Houston, TX.
What really ***** is that is a recurring lesson.:(
NASTYZEN
St-Colomban,Que. Canada
Found out that the old style 220v double fuse thing that you pull out of the panel was incorrectly labeled at my Moms. Pulled out what I thought was the dryer fuses when in fact was the stove.When I touched the dryer wires to skin them is where I found out something was not f*%$in right!:shocking:
wantedabiggergarage
Member Emeritus
Independence, MO, USA.
Don't work on oddball left handed thread stuff for a couple of days, then go to do something on the car when your on the phone (ordering parts). Your brain will still be in left hand thread mode and you will be breaking out the broken bolt stuff.
bluecomputer
Make sure you reconnected all of the electrical plugs BEFORE you start diagnosing/chasing down the problem. Ended up taking apart the interior before finding one disconnected wire.
justanengineer
Motor City
The ten second rule doesnt apply to certain floors...
That gravity *****...
That its possible to knock yourself so stupid you dont realize how hurt you are...
I could go on, but it would just make me look worse...
0.511MeV
I wonder if a chainsaw type glove that has kevlar in it would work better to prevent the cutting and tearing of skin. It sure won't absorb the impact, but maybe it will protect a bit better than plain leather.
I watched a safety presentation once that showed some photos of workers that had been hit in the face with bits of grinding wheels that exploded. The face shield group was a lot better off.
0.511MeV
I learned that halogenated solvents will strip the paint or finish off just about anything. Don't spill any on anything important.
I also learned that when working with acids and alkalies, you may not realize you got droplets on you until you wash your jeans and find out they are full of little holes.
After drilling out rivets, don't try to use your bare hand to pull a little ring of rivet metal off the drill bit.
TOOL MASTER
You can make a stubby screwdriver out of a 12" one with 200 amps...electricians and their bright ideas
AZ_Catskinner
Morenci, AZ
We've tried the kevlars - they don't slow that grinder down any either. Grinders casn be a nasty little animal, especially when they hit a rock or a piece of rubber liner.
WVBrady
WV
On old, 2-wire wiring, the switch may open the neutral instead of the hot wire. It is safer to kill the entire circuit instead of just turning off the switch. I wired up a porch light while the circuit was "hot" once.
ambenz
NW Chicago Suburbs
Certain "Gorrilla Glue" actually can be used to glue together two dissimular parts together because the glue actually foams up like expandable foam in a can...only on a much smaller scale.
Used it to glue a poster frame and noticed it foamed when cured so the light bulb went off! :shocking:
I had a remote control car (I use for car shows) that the hubcaps would never stay on...using the glue fixed my gaps in the part between the wheel hub and hubcap....that baby is on there!!!!
housey
Western Australia
Don't go sticking your hands where you can't see them. And needle resistant gloves may be needle resistant, but that doesn't necessarily mean they are scalpel resistant. This especially applies when you are doing work at a medical disposal facility
baubau
i learned many things trough my stupidity...
sometimes you learn things just by proceeding like usual.
last week i was pulling Kia Optima car frame using 15 ton puller....it was just little bit swayed and up, i applied little bit of pulling force in opposite direction and down, but, i managed to buckle the roof, crack the windshield and broke engine mount..
the lesson?...$2000 bucks later, kia is not a very strong car :)...and little bit of force is sometimes too much...
mrobins297aaa
south east michigan
I learned what it sounds like when you turn the power back on at the meter and unbeknown to me my partner had wired L1 and L2 to the ground bar on the inside disconnect............the house had overhead wires from the transformer, it sounded like a missle coming in..........it was not pretty.....lol
bartels_metal_works
Missouri
Might be time for a replacement partner.
