Jeff F
Couple of question about the LM 3800 openers. Lots of threads about them here, but if it's been answered before I can't find it.
I just installed a pair of these on 10H x 12W Amarr Classica 3000 doors.
1: When the doors were installed, the installers asked if I was going to put openers on them, and I told them yes. They wound the torsion spings pretty tight-- if I unlatch the door and pull up the slightest bit, they fly up, and I have to pull pretty hard to get them to go down. My guess is that they did this because it would be easier on a (regular) opener. Well, with the 3800s the door goes down kind of slow, especially at the top of the travel. Could this be because the spring has so much tension? Or does the 3800 pretty much have a fixed shaft speed regardless of load? I could have them come out and take some tension off, but I'm not sure if this would be wise, or fix anything.
2: Is it just me, or is it hard to mount the cable tension monitor in the way that they recommed? On my door, there is a metal angle that holds the door track and prevents it from being mounted on the outside of the door. I ended up with it mounted to the door header, inside the track, hinge down. Works fine (the door clears it on the way up... barely), except that it seems like if I ever tried to run the door all the way back on the track, it would exceed the travel of the sensor and yank it off. Seems like this would be a problem if it were on the outside too?
3. I haven't installed the remote lights yet, but before I decide where they go, I was trying to figure out if I could set them up so that BOTH lights went on when EITHER door was opened. I'm also considering wiring them up so that they just turn on the general overhead lights instead-- bascially just making it like another switch in parallel with the wall switch. Anyone done this? Also thinking that I could do this with one of the 395LM Remote Light Controls http://www.liftmaster.com/consumerweb/pages/accessoriesmodeldetail.aspx?modelId=839 but I still need it to respond to either opener. Thoughts?
