Air fittings?
SgtRauksauff
Baraboo
They ARE heavy, and HUGE!. But, my tire changer (Hunter TC3500) likes a lot of air, like 12.4cfm@135psi according to the manual. Milton's site says most 1/4" fittings will handle approximately 40scfm, 3/8" fittings will do 60scfm, and 1/2" fittings exceed 60scfm. Interestingly enough, it also says that the 3/8" and up fittings aren't intended to be connected/disconnected under normal air line pressure.
https://miltonindustries.com/uploads/Page_36.pdf There's some pressure-drop charts there too, kind of interesting!
--sarge
pcpro15
Can anyone spell it out for me :) One person say M, another say V, and T and... one is compatible one way and not the other :headscrat
I want quality high flow fittings because we just picked up a cman 33gal compressor and flexzilla air reel yesterday (50ft 3/8 id hose 1/4 connector). Trying to spend the money once and do it right. I want to use these fittings as long as I can benefit from them with my setup (but more for future expansion if I get a larger compressor too). I DO want reverse compatibility with standard fittings just in case my buddy brings his air tools over for some reason. I also want the freedom to to be able to go to lowes and pick up a regular fitting if I need to for some odd reason. What letter air fitting does that put me at? v, m, or other?
Or... should I just go to lowes and get regular fittings and call it a day
Thanks guys :D
jayoldschool
Canada
The fittings are not going to be the restriction with that setup. Buy anything.
shampoop
SW Washington
Thanks guys :D
There are only 2 style of fittings that have been truely popular throughout time. The M style and T (truflate) style. The V style is new and very similar to the M style except for it has a much larger hole inside and flows much better.
Get the milton V style fittings. Best design out there, gives you the most power. The female end of a V style fitting will also accept a M style plug. At work we use M style, but my home compressor is very weak and needs as much flow as possible so I use the V style fittings. When I plug my M style fittings into my V series female end, they do leak a very small amount sometimes. Normally you don't need 100% of power so it works fine, but if I ever come across something that I do, I remove the plug from my tool and put a V style fitting into it. Just keep some extra fittings lying around so you can install them on your friends tools if you need to use them. I have not personally seen a V style fitting available in stores, but the hassle of needing to buy them online is worth it. Just buy extra.
chewy7
WISCONSIN
milton v series here. V series couplers work with m, t and v series plugs. CarQuest sells them.
Now Leaving , NJ
milton L style is by far the most popular in NJ
PaulR
Hadley MA
I just ordered and installed a pile of Milton V's from Northern, full changeover in my garage......more money wasted...errr spent thanks to garage journal!!!
I'm just a hack homeowner Jeep guy but I noticed a BIG difference in my air tools after the swap. If you're looking to swap over all your tools and lines to a fitting, I strongly recommend the Milton V.
Mudman
I currently run M style. But thinking of switching over to V. However not sure if it's worth it considering I only use my gear twice a weak max.
fireguy
pretty popular in my area as well. that's all i generally see in auto shops.
"L"for Lincoln. I remeber the Lincoln # as 11993?
I use NAPA style D, because that is what the shops I worked in used. Now that is what I use in my business. I like the brass, they seem to stand up to the dry chemical used in fire extinguishers.
redcorvetteman3
Indianapolis, IN
Bought Milton V's a month ago and had one fail. The o-ring and brass insert broke. called milton and they asked what I was using them on. ( small impact guns, air chucks) Told me I was using them wrong. V fitting are are HLVP paint guns. The impact rattle breaks down the brass insert. So how are you guys using them in the shops? Now I have $100 in fittings and not sure what I should do.
alex71
SE Florida
I've had a couple of the couplers fail also, over the last four years or so. Still seems better than using 3/8 industrial interchange couplers. those are a pain, not to mention huge and expensive.
