Anyone install a wire raceway system?
Modern Jess
Bay Area, California
I've just acquired my first-ever garage workshop (some background here) and I'm going to need to rewire the whole shop from scratch. I've heard of people installing steel or aluminum raceway on their shop walls, even furring out the studs a bit to set the raceway back into the wall somewhat.
I'd be interested to hear what other people have done and what products they've used, and whether they'd do it again or not.
Gooch
Petersberg, IA
any 'non' flexible will be hard to run inside wood stud construction. I'd use Romex or MC if extra protection is wanted. if you want to something you can pull wire in instead of a cable, then you could use FMC or smurf tube.
mrb
are you talking about wiremold 3000 something like that? Youre looking at a significantly higher cost than traditional methods, and at what benefit?
Charles (in GA)
50 mi south of Atlanta
Depending on how complete your renovation is, if you are removing the wall shelving and workbenches or moving stuff around, you probably should consider simply pulling down the wall sheathing and running new wires/cables in the walls to a new panel. A 1966 building will not have grounded wiring most likely and I would not be surprised if it isn't 14 gauge.
Mount a bunch of 4x4 boxes with mud rings and receptacles in the right places, switches, boxes for lights, etc, pull a bunch of new 12/2 w/grd Romex and a new panelboard and have a real jam up setup.
Charles
ddawg16
S. California
The stuff is great if you have a bunch of stuff to run....your using multi-strand wire like THHN and you plan on making changes......but I think you will find that once it's in...it's in and you won't be making changes....beside the fact the **** takes up a lot of valuable wall space...
Modern Jess
I was thinking something along the lines of mono-systems SnapWay SWA2200. It would allow me the relative luxury of changing stuff, adding new circuits, and maybe even running compressed air in one of the separate channels.
Overkill, yes. Definitely. But I thought that was the whole point? :)
Modern Jess
Surprisingly enough, it is in fact grounded. There's even a single 230V outlet right below the panel. That said, the whole rest of the shop is fed from a single breaker, and it is woefully inadequate. I'm not keeping any part of the old wiring, and will be trenching for a new 100A feed from the main panel on the house (which is also getting upgraded).
W-Cummins
Iowa
Looks interesting but for my use it's useless because it's derated ( after 3 current carrying conductors) just like normal conduit is. Wireway allows you to run 30 conductors before derating is required. So that's what I'm using to move from my switchboard to my subpanels, and I'm thinking about ruining a couple runs down my wall too as it will be cleaner than a bunch of conduits.... I'm running nema 12 layin stuff but the nema 1 screw cover stuff isn't too $$$
William.....
W-Cummins
Iowa
What kind of wireway are you using?
What kind?? It is as stated, NEMA 12 lay-in style, Do you want to know what name brand's??
I have some Hoffman and also some Wiegmann stuff (as far as I know all the brands interchange??). I'm using the 6" stuff now ( seven 0000's in it now + more smaller conductors to come) but if I run it down the wall I will use 2" for that and I will use the cheaper NEMA 1 stuff ( probably the non-knockout stuff as I have punches and it looks cleaner). The NEMA 12 stuff is $$$$ New contractor prices for what I have is probably close to $2000.00 the NEMA 1 stuff is much less $$. Here is a link to the Wiegmann pdf for their wireway products.
William....
Modern Jess
Thanks for the catalog link. I've seen quite a few varieties of raceway, many of which have very different dimensions and front closures (so probably don't interchange).
Judging by the responses, though, it seems like this is not a common thing to do. Guess I'll just continue to muddle through it.
Aceman
Eastern Oregon
You could wrap the entire perimeter of your garage with this stuff!!!
http://www.hoffmanonline.com/produc...cat_2=2358&cat_3=2354&catID=2354&itemID=39988
Paint it to match, cut it to length if need be. You could go up and over door ways, around cabinets, THIS STUFF IS AWESOME. All the cool kids are doing it. Your neighbors and fellow garage junkies would be so jealous. I mean, who wouldn't want a wiring system you could pop out of anywhere you want to set a box?? Hell paint it a different color, make it a racing stripe. That'll really set your garage apart...
P.S. It'd even work as a makeshift shelf.
P.S.S. It comes in many sizes, the possibilities are endless....
You can't lose!
steelin3rd
Cedar Hill, TN
so what does this stuff cost per foot? or however they sell it.
ive hung cable tray back in my day but ive never worked with something like this. so you can just tap in and out of it wherever you like i suppose? can you mount a jbox to it?
im thinking about how this may work out running a run down the center of shop for drop down cords and hoses and such.
Modern Jess
Aceman
Eastern Oregon
If you don't like the price of wireway/gutter, I highly doubt that Hubbell stuff is any cheaper. A guy at work used a little bit of that raceway on a job though, I'm not sure if it was Hubbell or Wiremold brand, but he did say it worked slick.
jkary
Modern Jess.
Did you end up going this route? Was it really $17/ft?
Jason
