1950coronet600hp
- Joined
- Aug 14, 2010
- Messages
- 81
I want to have a 240v extension cord to be able to get to all points in the yard, what gauge flexible cable should i run for a 50' or 100' length? and where can i get it cheaply?
Did you check on 8/2? I think that would be plenty for what you are doing. When I did my "tabs" on my steel fence posts I just used 14/2.
By 50 amps are you talking the welder at 50 or 50 amps input at 220v with the welder at 200 amps?
where are you located? Dont buy the premade welder extensions that are made with PVC insulated cord (STOW type) it melts when anything hot touches it. You want rubber cord which is SOOW type
Now keep in mind that 50 amp run for a welder, 10 gauge wire is fine ...
SJOOW is acceptable also (300V insulation rating versus 600V), but most place don't discount it.
