I had a request for a better look at the mounting of the two vises on the stainless steel topped benches.
This one in the lift room is on the right side/end of that bench.
I used cap screws...
... which are really just large Allen headed bolts...
... but Snap On called them cap screws and Fastenal did too. Fine, whatever.
I do admit I think they look more finished than normal hex headed bolts would for what that's worth.
The vises came with a template to install them. I drilled them in a series of ever larger holes, lots of cutting oil and using a 1/2" drill to get through the 12 gauge stainless steel top. I had to frequently sharpen the drill bits to get all 8 holes done. Stainless is tough stuff!
For the folks looking for my boots in shop pictures, there they are....again. Add another picture to the count.
The bench top has a lip that tucks underneath the front edge so I had to make sure that the bolt going through the bench would clear that lip...
...and that the washer would mostly clear it. This also shows the end caps that were TIG welded to ends of the tops to finish the ends off.
By putting those end caps on it really finished off the ends of the tops. I still had to cut the front washers for clearance though.
And the other vise was installed on the left side/end of the bench in the north room. The tool box on the left can be rolled out of the way if need be.
Depending on what needs to be done, having the vises on different ends gives some versatility.
Thomas
