snap-on is much better
why ?
why ?
I might be wrong, but I thing that Koken doesn't give corrosion treatment.
What do you think the nickel and chrome plating is for?![]()
If you are in the USA www.levelchrome.com , talk to Alan.Is there a good web-site to buy Koken tools ?
oohhhhhhhhhhhh JK47 very,very sweeeeet, they are beautiful!!
How Z-series behaves?
thanks![]()
The Z-series ratchet is a 36 tooth, it has very little resistance when ratcheting. Reminds me of a well broken in Proto 5249, but with a much smaller head. The ratchet has a hard grip that has a very light rubber like grip to it. The Z-series sockets are very shallow, and the universal adapter is very compact. A nice example of modern design.
I'm in the process of replacing my old craftsman 12 pts with Koken 6 pts. Just ordered some 3/8" and 1/4" sockets. I like the "surface drive" design. Hopefully it'll make it easier to deal with worn nuts and bolts. Quality should be more than sufficient for my needs (home use). If I like them, I'm planning to rotate out all my old 12 pt sockets.
Thanks jk47,
"36 tooth, it has a very little resistance when ratching" It has or it seems?something has happened?
I don't know why Koken doesn't make any 45 tooth or more ratchet?
can you tell how much Z-series cost?
more pics and more reviews![]()
( I Know that there is a lot of threads, but I'd like to post here )
Yes they has, but the head doesn't seems like a "heavy duty", like they have the 4750J for example.
You think it is possible compare the koken ratchet 4750J, to other like the new Bahco 8150-1/2 ( which looks like Snap-on sealed head), or Hazet , etcc??
Because when choosing ratchets I really don't know what matters( I Know that there is a lot of threads, but I'd like to post here )
It is a little dificult when Koken has 36 or 45 teeth max, while others have more.
Anyone who has a koken ratchet, please review it![]()
Can you post some photos?
morning? Will do, fedex just dropped them off yesterday. Anything in particular you want to see...or just like the feeling ofmorning?
Question for those that use these sockets, I guess it's normal that they don't fit the nut with a "tight fit". Any issues with these in actual use? I grabbed a 10mm and put it on my snowblower (metric) and there is probably twice as much rotation as my c'man 12 pts. I dug up a 6 pt impact (COO taiwan) that I forgot I had...same amount of play as the c'man.
From my experience most ratchets with more than 36 teeth have a larger head, almost taking away the advantage of having a smaller swing arc.
Not snapons. Smallest head and 80 teeth.
My Koken Zeal , and KTC Nepros 3/8" drive ratchets are smaller than a Snap On F80 heads. Next time I have one for a comparison, I'll post pics.
Wow, that would be great I've never seen any quality tools with a smaller head than a SO. How many teeth do they have?
because of the "surface drive" i guess
Bingo! Just like the Metrinch-style profile.
RKA, I've noticed no problems with using the hand sockets, especially when combined with high-tooth count ratchets. I can picture a potential problem if you are typically using low-tooth count ratchets and you happen to be working in a very cramped area, where there's very little swing room to move the ratchet. That extra "slop" you get at the socket end could reduce your useable swing on the ratchet. In other words, it'll take more swings on the ratchet to remove that fastener. I think the primary purpose for using this type of socket is to remove marred fasteners--that's where they really shine.
JK47, Nice collection!!
The T60 and T70 are for Subaru applications?
good eye superautobacs
It doesn't really go with my Harley, but I have company F-250 that does Bingo! Just like the Metrinch-style profile.
Thanks! I'm thinking just like the Metrinch, these can be used with SAE hardware as long as you're careful to check the fitment. I have very limited SAE tools since my cars all use metric...but around the house SAE abounds. This might work out well!![]()
I was planning on getting a 2004-2006 forester XT this wintergood eye superautobacs
I thought that you with surface drive socket, would not notice difference using with low tooth ratchets, because Koken have 36 or 45 max.
And I was hoping that they will do job like socket 6pt or 12pt.
Would you post some photos?
