Die grinders.
JayL
Manila, Philippines
I dont care what anyone says with an IR you cant go wrong for the money, every IR air tool Ive ever had has outlasted any other brand that was in my toolbox.
Are the IRs you have the ones still Made in USA or do you have some of the Made in China too?
Thanks
JayL
Manila, Philippines
if you weld for a living, you should get a production tool. You're cheating yourself if you get anything less. Spend the $$$, or watch ebay and spend less $$$, but it will still usually be more than $50, unless you get very lucky.
I like Sioux (US Made only), IR (industrial production series, such as the G model numbers, or the older cyclone T & H model numbers), Aro (made by IR), French-made Chicago Pneumatic/Georges Renault, Atlas-Copco, Dynabrade, Henry, TC service, Dotco, and 3M. All great tools. Get whichever meets your specs at the price, and be happy. Some go for more than others, but the build quality is very similar between all of them. I like the Atlas-Copco full-size die grinders the best because of their spindle suspension. Really reduces chatter when using carbide burs. Don't be fooled by the low-end IR, CP, or Sioux. Not the same thing at all.
Here are the pics of my grinder drawers. Yeah, I'm a bit obsessed :D
What brand are these straight die grinders? (First pic :Two red ones on the right most front corner after the yellow grinder) tks
alex71
SE Florida
The two small red ones on the top right are Chicago Pneumatic. The two small red ones in the same row as the rest are Sioux.
4x4gearhead
New Hampshire
Thanks
I have an old grinder and 1/2 air drill US made, and still rolling. The rest of my IR stuff which includes an impact 2 90 deg. grinders, air recip, air ratchets etc are well used and show little to no signs of wear. I know that chinese ones would seemingly be worse but to be honest I dont really notice any difference in performance or longevity.
Monte
Germany
JayL
Manila, Philippines
How about this straight die grinder
http://www.siouxtools.com/force_abrassive_straight.php
( the last one on the bottom )
Sioux Model No. 5054A
• Lockoff lever throttle
• Comfort Grip
• Rear exhaust
• Built-in speed regulator
• Aluminum housing
• Power: 0.5 hp (0.4 kw)
• Free speed: 22,000 rpm
• Collet size: 1/4"
• Weight: 1.3 lb (0.6 kg)
• Length: 6.5" (165 mm)
• Air inlet size: 1/4" NPT
• Recommended hose size: 3/8" (10 mm)
• Air Consumption: 4.0 cfm (113 l/s) avg. – 16.0 cfm (452 l/s) max.
Is this a US Made tool?
Thanks
Monte
Germany
The Sioux "Force" line of tools is made offshore and it sold at a lower price point than the Sioux Industrial product.
the lowest price i found was $50.99 so i think thats too cheap for US made...
cnc-me
MI
IR's & CP's work for me.
Have a CP 860 that was used on production of stainless steel tubes,
still works good.
Greatbear
Columbia/Fulton, MD
I have a couple IRs that I've had for years and have been great performers. I recently picked up a larger Astro Pneumatic because it was cheap, it's on par with the IR models. And because I can't pass up a good deal, I bought two Kobalt die grinders that were being closed out at Lowe's, one straight, the other right angle. These little units are surprisingly good, with an on board speed controls and a nice composite housing. Both are very smooth and decent power for light or medium duty. The shape of the housings makes for a good grip while working, and the tools are surprisingly quiet. The rear exhaust can be aimed as well.
diy570
Clinton County, Pennsylvania
http://www.choiceavenue.com/tf/utils/ecx/img/41f%2BLBdLQ6L.jpg/IMG][/QUOTE]
i'm a dynabrade fan myself. i have a couple cheapies too, but i swear by the .5hp 7 degree offset dynabrades.
[IMG]http://i188.photobucket.com/albums/z160/victoryONE/009-25.jpg
Monte
Germany
@diy570
nice setup !!!
Do you have some close up pics of the Dynabrade die grinders in the upper left corner and the Blue Point AT401MCA in the upper right corner ? How is the torque of the Blue point tool ? Does it stall easily ?
diy570
@diy570
nice setup !!!
here's the picture of the dynabrades you asked about. the blue point in the other picture is a 3" da, it works ok, but i don't like it. the random orbital piece seemed to wear out quick and its kinda sloppy. i'll replace it with a dynabrade one of these days soon.
