Roller Chain Breaker Tool
Slowboat
Green Mountains
I need to do a one-off project (replacing the steering gear on my sailboat) with some 10B (metric roller chain close to size 50) and need to purchase a breaker tool. I was able to find 5m of Stainless chain on Ebay for $35.00 (which was a huge deal) so it's worth it to purchase the tool.
I looked on Amazon, and all the tools they had received crappy ratings.
Anybody got a favorite tool that doesn't break the bank?
Slowboat
Green Mountains
Did you get a 'soft link' specific to that chain? I suspect stainless is hellish stuff to rivet otherwise.
I have quick links that I will be putting on the ends (which attach to cable), so all I really need to do is shorten the piece of chain that I purchased to the correct length (4ft).
Ditchdigger
Eugene, Oregon
I just used this cheap HF chain breaker today on some Lynx Extra heavy duty 50 pitch chain and was quite suprised at how well it did the job.
I usually use this style
No idea on the brand, just whatever McGuire bearing has when I need one. But I have to say I prefer the cheap HF version and am going to look for a better quality one.
kms
D.I.D Chain Cut and Rivet Tool KM500
What I used when I used to have a bike. Expensive, but quick, durable and very easy to use. As mentioned, grinder works fine too.
airbuff101
It's a cinch to just grind the pins flush with plate (one one side) w/ a bench grinder, then punch them out w/ a straight punch and hammer.
2 minutes tops. You don't need a chain breaker.
airbuff
pacmktg
Foothills of CA
I sell roller chain for a living.
1. Use a die grinder and a punch. Do not waste your money on a tool you will use once.
2. Stainless Steel chain is softer than carbon steel by a lot. It is much more corrosion resistant though.
