Blind hole caster mount, advice wanted
TheGrooveking
An alternate reality in a parallel universe.
I am looking to mount 4 swivel casters to the bottom of one of my job boxes, but the problem is that the lower pedestals as I call them are all heavey sheet metal and welded on all sides, thus no way to place a nut on bolts. I want to mount the casters using screws, like self drilling sheet metal screws but am concerned with stripping. This box doesn't see a lot of use, but the last thing I want is to be moving it with 400 pounds of tools in it and have a caster come off. I do not want to weld the casters on, as that I may take them off when needed. What would you guys recommend?
The box in question is like this, except the legs are enclosed, no openings for access.
TheGrooveking
Tatsuya
Seattle, WA
Can you mount it to a dolly and instead of taking the casters off just lift it off the dolly?
nehog
Jaffrey, NH
The suggestion of nut-serts is a good one, also see how thick the metal on the bottom is. You may find it is thicker at the corners to allow mounting of wheels. In that case you might be able to drill and tap some holes.
Also I'd not use self drilling screws, instead pre-drill the holes and use self tapping screws, and then very slightly undersize the holes. Use care not to break off the screws the first time. Reason is that self drilling screws seem to over size the holes, at least in my experience.
Another easy choice is to weld some 1/4" plate to each corner, then drill and tap the plate for bolts. The 1/4 plus the base thickness, would be sufficient to hold most anything.
Quiksilver
Loveland, OH
I like the cart idea. If you often need to lift it with forks, you could make two carts out of angle iron, one for each "pedestal" as you call it. Then attach with rivet nuts through the side. This puts the bolts in shear, meaning that you don't have to worry about pulling the threads out.
larry_g
oregon
Make a horse shoe shaped plate that will slide over the 'leg'. Drill through the horse shoe and the leg and then put the bolt through and a nut on the inside. So in other words the bolts will run parallel to the floor instead of verticle up from the bottom. Bolt or weld the castor to the horseshoe. You could also run bolts from the inside of the box through the bottom of the foot and bolt the castor on that way.
I highly suspect that the box has a reenforcement in the corner for castors esp if castors are an option on the box you have. Call the mfg and ask.
lg
no neat sig line
tfi racing
Cedar,BC
Have you looked at the bottom yet?Both my Greenlee and cheap imitation no name job box had threaded nutserts for casters welded in from the factory.
Falcon67
Merkel, TX
I would get a couple of pieces of 2x2 tube, weld the casters to that and mount the tubes to the bottom right next to the legs. Or go ahead and add some angle, tie the tubes together to make it a full dolly that fits between the legs and then just self-tap from the box bottom into the angle.
dumper
Oregon
how about a large-flange style nutsert, spot welded in place? I would not trust the nutsert in this application without the weld.
T
TheGrooveking
Mike14k
Very rural Oklahoma
I've done this exact thing a couple times... a 3/4' ply platform the job-box sits on, with blocks to hold the "pedestals" in place. And the casters attach to the ply w/ fender washers and appropriate bolts.
Works great...
RobSmith
NSW Australia
yeah, build a dolly and someday you'll just need such a dolly to move something else.
Two problems solved ! I built a dolly for a spare engine & gearbox....it comes in real handy for moving other heavy stuff.
rockchucker
Seattle WA
Maybe some C channel large enough to house the Pedestals. Weld Plates on the end of the C-Channel to stop them from moving around. Drill and countersink the holes for the bolts for the Casters. Mount the Casters on the bottom of the C-Channel. Lift Box and set on the C-Channel. Drill through the side of the C-Channel and through the Pedestal to install a through Bolt it you feel the need. You could even install 3 lighter Duty Casters on each rail instead of 2 large ones to save on height and price.
Or use Self Tapping screws through the Casters into the bottom of the Pedestals.
I would weld on good, high quality, replaceable, grease-able, Locking Casters if it was my box though.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
4 pieces of angle iron. Build a square frame with casters welded to it, then set the box inside of the frame. Paint the frame black or paint the frame to match the box.
Tink
Old Bridge,N.J.
Drill through the legs into the bottom of the box and use bolts. If you don't want the bolts sticking through the bottom you could oversize the holes inside the box so you can get the nut to the bottom of the leg.
bgott
Houston, TX.
This box over 15 years old, they didn't provide any holes on the bottom, so of course there are no threads to put bolts into it.
That's where the "self-tapping bolts" come into play.
kbs2244
Building a dolly is the best idea.
But with a fully assembled furniture dolly at the big boxes for less than $20.00 I have to think they are the way to go. (When I asked why they are cheaper than 4 identical casters alone all I got was a shrug.)
Get 2. Bridge them with a 2x4 with holes lined up to holes you drill in the feet.
Bolt and screw together and you are good to go.
