I have seen the lab articles a couple of times in a few different mags. They are definitely a joke and everyone here knows that. Most people who shop there (in my area) dont have all their teeth. Not to be degrading, but they arent wrenching for a living and if they are its not aplace that comes highly recommended for service reliability or ASE type work. You can count on that. Will that change? Who knows.
About the torque wrenches. One thing is they are better for a weekend warrior and I wouldnt probably put a race engine together with one, but my differential cover is cool. I cant reliably torque 15 bolts to 30# with a 3/8" ratchet of any brand. If I had to pay $300 to get a SO, I'd use the ratchet and check for leaks every few days until I new it was good and then I'd quit checking. Not a race engine.
The torque wrenches from HF are fairly tricky to understand if you dont have all the info. Its like they (HF) would like you to break some bolts and raise 4 types of hell so that they can calibrate and show you how wrong you are. You would generally be wrong in this case. First, they are spring loaded and should NEVER be kept wound. You should unwind them everytime you use them. Second, you have to wind them in and out (cycle) one time before setting them. If you dont, here's your sign for being a DuMass. Read all the fine print and you will uncover this. This will prevent bolt stretching, bolt breaking, borrowing your buddys' tools and overspending on like items. Most people dont read well, jump to conclusions about what they 'thought' and break **** and blame it on the tool. The tool was perfectly fine in the box and didnt break anyhting until some mechanic decided to use it incorrectly. Guys with $300 TqW's are NOT sending them in regularly for calibration, despite what you hear here. If they are or want to argue over the web, just post a receipt and I'll issue an apology. I have had the over clicking issue and that's how I come to realize my inability to follow directions. I fixed that. There's a very detailed post that explains this in detail here, somewhere.
