I'm looking for a heavy duty eyebolt that I would be able to anchor down into my concrete driveway, where I would be able to chain a scooter/motorcycle to. Any ideas where i can find one, and what is the best way to go about anchoring it? Thanks.
I would think the absolute best way would be to bust up a section say 6'x6', weld the eyebolt to a piece of steel 2'x2' and then pore concrete back in covering the steel. The eye bolt wouldn't be going anywhere
I would recommend drilling a hole and using a bolt setting epoxy such as HIT-RE 500-SD Epoxy Adhesive to set your Eyebolt. http://www.us.hilti.com/holus/page/module/product/prca_rangedetail.jsf;jsessionid=FB7DFD2728C0AC728FDB82398B358472.node2?lang=en&nodeId=-58689
Maybe a couple concrete anchors and a bolt-on tie down? This way it folds pretty flat and won't be a trip hazard.
That sonds good, is that available at home depot?
Have you considered a pull pot?
http://www.gradeatools.com/MO-Clamp-3071-MO-TY-Chain-Tie-Down-Anchor-Pull-Pot-p/mo-3071.htm
Would yield a flush surface when not in use
I got my eye bolts from Home Depot that I use to chain down my tool box, tablesaw, mitersaw. it's pretty thick bar stock, maybe 1/2" diameter. I drilled into the concrete, set a drop in threaded concrete anchor that matched the threads on the eyebolt and put red loctite on. It's set pretty deep, I think I drilled about 3" into the concrete. I'm not worried about them twisting it out since with the chain on that would make it practically impossible to do. For the chain, I'm not actually using a chain but the thickest lockout cable they had. The cable is very stiff and harder to maneuver then a chain but since it's vinyl coated it does not scratch anything.
