ddawg16
If it's not one thing....it's another....(I'm doing a 2-story addition to my house)
Had the Electrical Utility guy out today to confirm the location of my meter....I have a slight problem.
Per the specs....the weatherhead needs to be within 3' of the roof line so that the linemen can access it with a ladder from the ground....
I do not have enough clearance on the side.....I have a block wall on the side...and when you calculate the distance the foot of the ladder needs to be from the house in order to reach the roof...the ladder is outside of my property....and the rules say that the ladder has to be on my property...
That part of the house has shear walls....I can not have any penitrations in the 1st 4' from the corner....so I 'had' planned on my meter being 6' from the corner....that is too far from the back corner (can't be more than 3').
What if my weatherhead entered the roof at the back corner (which would put it within the 3' distance) and then I had 2 45 deg sweeps through the wall so that the down pipe ended up on top of the meter?
So the real question is....can I have the 2" pipe for my power to my panel go at a 45 deg angle through a couple of wall studs?
