Craigslist score
outlander800
I hit the craigslist tool section today and found a 8 inch baldor bench grinder. Its a 3/4 hp and its 3 phase. Got it for $60 bucks. Just dont know what its going to take to get this thing wired up in my garage correctly as I dont have 3 phase.
baldor grinder.jpg Sorry for the crappy cell pic. Its actually in real nice shape, but hard to tell from that picture.
darkk
Willimantic, Ct.
3 phase, really? why do you say that? Is it marked 3 phase? Just curious, not being asmart ***. Just never saw one wired that way...
kc-steve
Kansas City
No doubt the wiring is why it was priced low. Look on Google for wiring a 3-phase to single phase.
Steve
Delbert G
For less than $200 you can purchase a VFD (Variable Frequency Drive) which will allow you to run the 3 phase motor from single phase input.
littletoes
NE Washington
Not sure, but I don't think a VFD is for "converting phase's", its for varying speed of specific motors, its used for energy conservation on commercial/industrial site's.
Perhaps a phase converter might be what you want for running a 3 phase motor on household voltage.
stock z/28
I have several 3/4-1 hp and bigger grinders in the shop that are 3 ph, but I have 3 phase, so its no big deal.
As inexpensive as a decent single phase grinder can be bought for I am not sure of the practicallity of converting a 3 ph to single ph?
I think a VFD would do the conversion for you but I have never seen one used on a small bench grinder. It may work fine.
Good Luck
Jeff
Amitygravel
Claremont Illinois
Whatever way you end up wiring it , you still got a Baldor for 60 bucks.
New ones are not cheap by any means and that thing will last a long time.
2oolhound
BC Canada
+1 on the VFD but it's an expensive solution to a 3/4 hp grinder. However if you are planning to expand your shop with other HD equipment it doesn't hurt to invest in one that will be compatible to a lathe, compressor, welder or other 3 phase equip. (you only use 1 at a time). Keep in mind a VFD is dedicated to specific size motors so all equipment you wish to use it for must be very similar in HP.
bluebolt
Benton LA
You have the same problem as me, a 3 phase Baldor LOL. For now I am going to "shelve" it but in the future will get a converter.
O
outlander800
The grinder could use a new set of wheels and a quick cleaning, otherwise its good. Im probably going to hold on to it till I have another piece of 3 phase equipment to hook up to make it worth while financially. Would a single phase grinder that is 3/4 hp be as powerful as this one being 3 phase?
