I also live on an airpark, and I painted my hangar floor a couple of months ago with Wolverine.
Here's a link to the thread:
http://www.garagejournal.com/forum/showthread.php?t=103273
In the past two months I've drug floor jacks and engine stands across it, dumped used oil on it, spilled gasoline on it, and even hammered out some u-joints on the floor, and so far I have not found anything that will even scratch it. The floor is not slippery at all, I believe because of the fairly heavy chip broadcast which provides a lot of texture.
Thanks for the endorsement! I should mention that u230148 is the official recipient of our "Single Seater Solo DIY Pilot" award - he coated that entire hanger floor by himself!
BTW his materials were BondTite 1101 (6.75 gallons), LiquaTile 1184 (15 gallons), both 100% solids epoxies, and a clear coat of EnduraShield 2254 (6 gallons) - a polyurethane. The final cured thickness of the coating system is around 23.3 mils (not factoring in waste or DecoFlakes).
U230148,
Your floor looks great! I have about 2400 square feet so close in size for my project. From what I have read grinding the floor provides the best preparation vs. etching it. I need to investigate renting a floor grinder. Did you use / rent a large grinder and how much would you say use used in materials to complete the grinding portion of the job?
Thanks again!
mmesa005
Walk behind grinders come in various sizes from around 12 to 28 inches, there are both single and dual head ones, propane, gas, electric etc. A common rental model is the Edco Dual head at 22". Besides machine specs prices also vary greatly, the 22" goes anywhere from around $140 to $240 /day or so.
Call local tool rent yards and let them know what you need to do, whether or not you need to remove any existing coatings, etc., they should be able to steer you to the right equip. Mention that you'd like the final floor to have the texture of 120 grit sandpaper or close to that.
