li0nhart123
- Joined
- Jan 5, 2008
- Messages
- 57
Received my 10 piece set of craftsman professional wrenches today...I am impressed with the finish...smooth as a baby's bottom with a mirror finish. This was a replacement set for the one I had to send back due to a cracked wrench making it past quality control.
Although the wrenches are nice in appearance and feel balanced when holding them, you can see the grind marks under the chrome on the inside of the open end. I guess I can't complain, I only paid $29.99 for the whole set.
Since the wrenches are so shiny, I was unable to get good pic with my camera. I ran one through my scanner to give you peeps a look. As you can see in the pics below, the scanner compensated for the mirror finish by showing it as grey.
"Craftsman" and the size clearly ans crisply cast into the top side of the wrench.
The part number and size are cast into the back. No country of origin is cast into the body of the wrench.
Clearly imported as indicated on the package..I'll assume it's china or taiwan.
Other than the few grind marks present in the open end,,I let em pass the visual test.
I won't really get to put them to use until spring..hopefully the will hold up. they do come with the lifetime guarantee.
I'm sure some of you must have comments...
