diesel research
A bunch of stuck hydraulic hoses put me in a bind this weekend. Mostly in the 1-1/4 to 1-5/8" range or there abouts.
Obviously I don't have a complete selection of open end wrenches to cover this range.
A buddy had several raised panel wrenches that covered about half the sizes I need. Some cman, some HF. Didn't matter, because they didn't have the length needed to do the job, nor did we have enough sizes to cover the other half of the fittings. Probably 25 fittings, almost all seized on.
I avoided using the torch, because a torch near rubber lines and hydraulic oil is probably not the smartest move.
Ended up having to use a combination of the wrenches, a pipe wrench, and my 15" adjustable which wasn't long enough or open up wide enough. To top it off, it required abusing them with a 4lb mini sledge. Even then some didn't come off.
In the past, I have used hydraulic force to lift/pull/push wrenches in the direction I need, but that wasn't an option this time. I was standing under a truck, in an oil change pit. The PTO which usually sides off with minimal force, wouldn't budge with my SO 24" hammering prybar, and required a 16lb sledge to knock it free.
Not wanting to be in that situation again, I want to tool up in preparation.
I was considering this set of crowfeet which seem pretty complete, and coupling it with the old 24" breaker and/or pipe.
http://www.northerntool.com/shop/tools/product_200401867_200401867
