autoclassicnut
I am in the process of converting an old Lincoln lube cabinet I picked up to a oil drain catch for under my lift. Here are some pictures of the progress so far.
Before...
Before...
Whatcha gonna use it for?
Beautiful ! Did you have to rechrome those pieces , or were they in good enogh shape to just polish ?
Check the music stores or pawn shops for a microphone stand. They are extendable and should be plenty sturdy. Look the mike clips over too they might be of use also.
Craig
Those were often bought as a matched pair. By that, I mean the grease gun like you have was paired with a similar looking oil drain. Your restoration is not too far off from the original version. The cover sat on a dolly, inside was a larger oil tank (around 16 gal. IIRC) with a drain spout in the bottom that ran outside the cover. Waste oil tanks were underground in those days so you just pulled it over the tank opening and drained. The drain funnel and telescopic tubing was held in place by the top cover and the tank was sealed to prevent spillage. Great Job!
Lou
Hey autoclassicnut,
Looks fantastic, thanks for sharing.
Maybe your next project should be getting the brakes on that '38 fixed, when they lock up like that they are leaving nasty marks on your floor GRIN
I hate to break the news, but your green "funnel" sells for well over $100 on Ebay.
