another show off your tool bag thread
tonydanzah
the champagne of people
After work the other day I figured I would clean and organize my shoulder bag. After I had it cleaned out I decided to take some pics for the GJ members. Not sure the weight, but I think its around 60-70lbs.
Carl B
Clearwater, Florida USA
Great idea for a discussion thread...
I just got back from a 700 mile road trip in my 72 240Z. The Z now being close to 40 years old - I always pack an "emergency" tool bag. Although I've only had to use anything out of it about twice myself. Once to disassemble an electric fuel pump & repair it on the side of the road. Once to re-route {loop} a heater hose that blew out. Nonetheless an ounce of prevention so to speak.
One of the beauties of the 240Z's is that with the tools below - I can pretty much disassemble/reassemble an entire 240Z if necessary.
Heading out to the garage to get some pictures....... OK...
In the picture below:
Spare Fuel Pump, Dist.Cap,Fuel Filter,Points/rotor/condenser -Craftsman Tool Bag
Spare Fuel Lines, Clamps, Pliers, Rubber Gloves, Mechanix Gloves, Leathermantool/Maglight,Cutter
Craftsman Socket Set, with Screwdrivers, Screwdrivers,Ratchet, Extension, 8mm to 19mm Wrenches
Line Wrenches 8mm to 12mm
Everything fits in the Craftsman Tool Bag - except the spare Fuel Pump. I also carry a bit of 18,16,14 gauge electrical wire, electrical tape and a few electrical connectors in the spare tool compartment in the car. Along with the spare fan belt, rubber brake lines and radiator hoses.
Some of the spares, I carry because several Z's may go together on longer road trips. I also carry a cooler for cold water - but sometimes it is also spare coolant for the radiators if needed.
FWIW,
Carl B.
Neuswede
Central Pennsylvania
great idea for a thread...here's one of my bags. This one I keep in the daily driver (a Z71 Tahoe), but I supplement the gear depending on what I may potentially need to fix.
The bag is a Craftsman, then the plastic boxes are Flambeau, found at any tackle shop. For the socket boxes, I take my Dremel and cut out the molded dividers and sockets fit nicely with the rails. For travel, I carry the full range of sizes, but limit the number of sockets for drive size, so I have 1/4", 3/8" and 1/2" on the same rail. Each socket box is labeled either Metric or SAE, and includes an assortment of regular and deep-wells, all 6 point.
Most of my cars use Torx, so I keep plenty of those. I like the flexibilty of using GearWrench ratcheting box wrenches, and also have sets of the flex head type also. For screwdrivers, I carry a full set of bits, and have several ratcheting handles, extensions and gizmos.
For my ratchets, I keep a full complement, with flex and regular extensions, and adapters.
Depending on my needs, I also can carry a test light, test meter, extra leads, and an extra battery for the meter.
I also include some small items like needle nose pliers, vise-grips, wire cutters or crimping tool, depending on the anticipated need.
For night work, I keep several flashlights at hand, in all my vehicles and also in the tool bags.
Along with the flashlight, I also keep a magnetic pickup tool (the kind with a small LED on the end) and has proven highly valuable many times.
Each car has a spares kit (bulbs, relays, fuses, etc.). I also have a separate plastic box dedicated for trailer towing, which holds the draw bar, extra clips, pins, quick links, chain and plug repair parts and plug tester.
I also keep gloves (work and Nitrile) and a first aid kit in each car, so they don't take up any room in the tool kit.
The labeling helps with marital bliss..."honey, hand me the box labeled metric wrenches". It works much better than "honey, hand me the ratcheting flex-head 10mm wrench":wtf:
NUTTSGT
Northern Central Ohio
I've been thinking about taking some pics of my tool bag in the truck. It's a little late to do it now. Besides, the wife has the camera and I hope I see it again.
BigAl62
suburbs of Chicago
That is a great idea, I'm going to have to "borrow" it!
T
tonydanzah
What do you do that you need to carry so much?
field service for gas/electric lift lift trucks, scissor lifts and floor scrubbers. Often I have to park out side and work on a downed truck that can be 1/2 mile away in some warehouses so I try to carry as much as i can so I have less trips back and forth. I have alot more in the van, and I usually carry another bag with a meter and testlight.
Arne73
Here's mine. I'm a maintenance mechanic at a bottling plant.
Metric on the left, SAE on the right. Xcelite & Vaco screwdrivers (only amber handles in the shop, easy to spot) Klein dykes, slip joints and Linemans.
All this weighs 25 lbs so it usually rides around on a cart. I carry this on my belt:
My common quick fix tools: Klein tweeker, HF 6-in 1 screwdriver, Facom 7/16, 1/2 9/16 10mm and 13mm angle wrenches, 6" Channel locks, 10mm 13mm and 17mm stubby ratchets, an old MAC 7/16 combo, unknown 1/2-9/16 open end and a 6" adj.
Mr.Nutcase
USA
What brand is the ratchet?
I think it looks like Matco?
cruiser808
Hawaii
Extremely impressive, gentlemen! If I ever break down on the side of the road, I hope it's one of you guys that helps me out. You all will be on vacation, of course.
:bowdown::bowdown::bowdown:
volpster31
SOUTH JERSEY
i think its great that G.J guys have cool bags with quality tools ...i hate how the guys i work with have junk tools and dont give it a second thought.and they wonder how i can fix anything with the tools right in my bag:thumbup:
scylla
I was looking for another bag to carry and really liked the look of those Veto totes.
Then I looked up the price for one. Absolutely shocking. Guess I'll stick with Bucket Boss.
Slip_Kid
Rhode Island
I have tried many types of bags to carry my tools. I have used electrician pouches, and many types of bags. The Veto bag is by far my favorite, a bit heavy I will agree. It has a nice shoulder strap that helps to carry it around.
PhantomEB
Medicine Hat, AB, Canuckistan
Just got into the Millwright trade as an apprentice and with Canadian tax laws, I get to write off most of my tools thru out my apprenticeship.
Need a tool bag damn soon, only got a 180 pc socket set and a set of flex head gear wrenches.
Tryin as much as possible not to touch my garage tool box for tools just yet as I intend that the Tool bag will stay with my Daily driver truck as well go with the offroad truck whenever. In other words, goes where I go!
Neuswede
Hey Neuswede, that is a good idea too keep the tools in plastic bins
They work nicely for most hand tools. What doesn't can be persuaded with a Dremel. I am looking at some other types of boxes from US Plastics that may hold a wrench assortment a little nicer. If I can find some boxes that vary just slightly in size from what I have, there is probably some extra room to take advantage of, too. I also have some Plano boxes to keep my smaller ratchet straps, and another much larger heavy duty box for my car hauler ratchet straps and tie-downs. I try to keep everything in a grab-n-go format.
