72in Matco 5S rollaway.
action fab
Hot Springs, AR.
I bought this box about 6 months ago... It was on the truck for a while so I am sure its a 2010 model. I have taken very good care of it. There are no scratches or dents... though the counter top is a little stained from dirt. I had the same thing happen to my old box and my dealer used simple green to take care of that.
I just had the box empied out by thieves... :rant:
So I need the money to buy new tools and don't need this big of a box at this time.
It is actually a 5228 with a side box added... I don't have pics tonight... but it looks just like this one below. Though it is all red with out the graphic and it has brushed alum. trim.
It was $7400 new... But I would like to get about $5000 for it. I may take a smaller box in on trade.
Random box I found online that looks a lot like it, same boxes diff. trim/ mine has no graphics
this is the only pic I have with my box in it. I'll take some more though.
Big Top GT
Coral Springs, Florida
Sorry to hear about your loss, man.
They say that in most cases of theft, you usually know the person who stole from you. Start thinking about who's been in and out of the shop lately, as well as who hasn't been around in a while.
This is a lot of expensive gear. It has to be something people would notice if it gets put up for sale.
Do you have any odd tools you could identify in a sale?
I'd start looking at eBay and CraigsList for tool sale listings. :)
A
action fab
Hot Springs, AR.
Yah $41,000 worth... they broke into my shop and whiped out the box, got my miller 250x and thermal dynamics cutmaster 52. The worst of it is my insurance isn't covering any of my loss. I have been working on "the case" for two weeks now and I have tracked it back to a drug dealer who is MIA... So now the DTF is after him too. I doubt I'll ever see any of it again though. :sad:
A
action fab
Hot Springs, AR.
List of the stolen stuff that I can think of... I'm sure I missed plenty
red plastic creeper Matco LOGO (this one has bolt on wheels)
matco, witte 8pc red screw driver set.
matco 1/2 chuck 19.2 drill W/out batt.
matco yellow and blue quick grip wire strippers
matco 1/2 drive, locking Flex head wratchet, long handle, 60tooth
red plastic creeper Matco LOGO (this one has snap in wheels)
matco 5 pc ballpein hammer set. (3 yellow BHP/PN) (2 red FH/PN)
matco 10pc metric combo wrench set, long 12degree, 12pt
wrench rack yellow
wrench rack red
1/4 sae socket rack
1/4 metric socket rack
3/8 metric socket rack
3/8 sae socket rack
1/2 sae socket rack
1/2 metric socket rack
matco7pc 3/8 extension set, 1,3,6,8,10,20,24, knurled shank,
3pc knipex diagnal cutter set
10 inch knipex slim jaw cobra pliers
1/2" matco impact. (old, red, and dirty, with new silver front bell)
automatic spring loaded center punch
KD Gearwrench flex head 8pc SAE combo wrench set. With wrench rack.
kd Gearwrench flex head 12pc combo wrench set. With wrench rack
Matco, cobalt drill bit set in metal index case, 1/16" to 1/2"
matco 5 pc blow gun kit in red blow molded case.
3/8 Matco tq wrench in red blow molded case 10-100 in-lbs
3/8 drive, SAE, 9/16, 12pt, shallow, socket
matco 5pc socket adapter set 1/4"-3/4" adapters.
matco 1/2-3/8 socket adapter
Matco right angle ratchting screw driver set.
matco ignition spark tester
Matco 16 pc quick change bit set in red blow molded case torx/phillips/nut/ 3/8-1/4
matco Low clearance pitman arm puller
25" matco flex, spring claw, pick-up tool.
Gearwrench serpentine belt tool kit. 15pc
OTC rear axle bearing puller set for slide hammer
matco red handle brake spring tool
brake spring pliers
2 1/2 matco telescoping inspection mirror
1/2" impact universal joint
3/8 impact universal joint
1/4 impact universal joint
80 degree spring loaded push pin plyers
4pc Gearwrench inverted torx, fixed ratchet wrench set in brand new grey wrench tray
4pc Black Hawk e-torx proto made gearwrenchs
Matco diegnostic smoke tester kit.
disk brake caliper compression tool
Matco muffled air mini saw with swivel inlet
silver eagle 3/8 drive 1-1/16 sensor socket
matco 19mm twist lock 3/8 drive socket
3/8 drive matco stubby flex head ratchet.
3/8 Matco 11" 88th ratchet
3/8 Matco 12" flex ratchet, non locking
mps700 scan tool case
mps700 scan tool, import cable kit
compression test. One hose is wraped in Elec. Tape on threaded end
Cyl leak down kit with manifold and hoses
lisle master disconnect tool kit
lisle master bearing, race and seal driver tool kit.
lisle brake line double flaring tool set
lisle 1/2" drive stud remover
lisle pitman arm puller
lisle 3/8 hand Impact driver set
power built ball joint removal/install tool kit
power built slide hammer
19.2v Matco 1/2 impact
19.2v Matco battery
19.2v Matco Cordless flashlight
Snap-on extra long reach double hinge needle nose plier 3pc set.
snap-on Breaker Bar, 45° Offset Square Drive, 24"
Snap-on green handle pick set
Snap on 3/8 drive, knurled, function ball extension
OTC 4wd socket kit
Matco 15" orenge hard handle hose hook tool
1.5" proto adjustable spud wrench (cresent wrench with a spike shaped handle)
craftsman 2pc red handled cushion adjutable wrench set
Craftsman Digital Multimeter with AC Voltage Detector
Craftsman mini coil cord test light
Craftsman 44pc Mini metric/SAE wrench set
7pc SAE cushion grip nut driver set (discontinued)
10-15 mics craftsman hard handle screw drivers philips/flat head.
BGS 12pc Screw driver set in blue blow molded case… Top Lid Is Cut Off Case.
Craftsman Air hammer
Craftsman 4pc chisel set
drawer full of mics. Chisels and punches… about 30-40 pc
Craftsman 107 pc Tap and Die set Metric Die Set
Old craftsman Die set SAE in grey case 1/4-1/2 fine and course
Craftsman 4 pc flair nut (line wrench) SAE set
Craftsman 1/2 x 9/16 tappet wrench (long , thin)
chrome vanadium stubby SAE wrench set (one SK 9/16)
chrome vanadium stubby metric wrench set
Cresent SAE reversabe wrench set
Gearwrench straigh ratcheting wrench set. SAE
Old MAC double open end offset wrench 1-1/16"
Old Mac double open end offset wrench 1-1/4"
OLD snap ring plier set (Nonreversable) black oxide, no grips, no markings
Craftsman Extra long "large" magnetic pickup tool black handle 16lb P/U
10-15 vice grips, Flat jaw, curved jaw, needle nose, C-clamp, rivet, sheet metal.
Craftsman compound leverage snips, straight cut. (yellow handle)
8" Journeyman Cable cutters, Orenge handle, unmarked, well used. Freshly sharend.
Vintige light green handle needle nose pliers, smooth jaw, with no dike blade
3 mics, 5" needle nose w/dike blade. One with black/yellow stripe grip
5 pc Large wrench set 13/16-1-1/8" unknown brand… china wrenches
3ft green handle pry bar. Handle is broken on the top and shaft is showing.
very old will used tire spoon from tire machine.
20-30 carbide bur bits… all shapes and size, some long some short. 1/8 shank
harmonic ballencer puller. Unknown brand
steering wheel puller, Home made 1/4" plate with welded nut. Bare matal
3 jaw puller 4"
Matco 14.4v 3/8" cordless impact. w/batt. And a charger.
Matco 14.4v battery
Matco silver eagle 41pc torx, socket set. Red blow molded case
3/8 drive Master grip SAE/Metric deep and shallow sockets 3/8-7/8, 10mm-22mm
3/8 drive master grip ratchet 8", push button release.
1/2 drive deep Black oxide SAE/Metric 3/8-1-16, 10-24 (Markings warn off.)
1/2 drive master grip shallow 12pt SAE/Metric sockets. Chrome 5/8-1-1/8, 15-27
Matco 5pc spark plug sevice set (swivel, magnetic , extension set)
metric allen wrench set. In blue sleeve
SAE allen wrench set, in yellow sleeve
master grip 1/4 drive SAE/Metric deep/shallow socket sets
MATCO 1/4 drive 6" non lock flex head ratchet
Master grip 1/4 drive ratchet. Push button release
5 or so misc. 1/4 drive extensions.
blue and grey 2 lb dead blow hammer. I cant remember the brand.
craftsman 16" pry bar. Hook on one end, pinch on the other
craftsman arc-joint pliers 16"
craftsman arc-joint pliers 9"
craftsman arc-joint pliers 13"
craftsman arc-joint pipe pliers
Old unknown brand 3/8 air ratchet.
vintage unknown brand 1/4 air ratchet.
vintage 3/8 butterfly impact
MATCO Blue Air riveter. Unknown brand
Right angle mini die grinder
(3) straight line die grinders. chrome.
HD high speed straigh line die grinder.
Ingresoll rand 3" air cut-off
Guardair 12 in Long John Safety Blow Gun
Guardair jet guard safty Blow Gun
rubber tipped air blower
dual foot air gauge
Matco digital tire gauge
valve stem remover/installer
Vintage dual angel tire inflater, Brass with slight petina, very old hardend pipe tape.
vintage campball hausfeld 1/2 impact
Ford clutch fan wrench.
OTC Master Noid light set
Unknown brand Audio stethoscope
Matco Oil filter wrench set. Small black handle/Big Red handle
Matco Nylon strap Wrench 1/2 drive. Black belt.
OTC cooling system pressure tester.
Green hard handle Hose Hook
9/16 GM distributor wrench
Large red Red tubing cutter. Paint pealing from brake fluid
Red handle tube (brake/fuel line) bender
pickle fork
silver 10" mini level unknown brand
4 or 5 12 and 30 ft tape measures.
Power steering pump/universal pully puller/installer. (in craftsman air hammer box)
Titan yellow and black handle1" carbon gasket scraper. Freshly sharpend
6pc black hand torx drver set un marked
10pc Craftsman drill extractor kit
3/8 drive tap wrench
bully dog power pup programmer 01-08 GM truck.
KMC xd Rock Star black 20x10 6x5.5
37x13.5R20 nitto mud grappler
double din in dash DVD player (unknown model)
mono amp. Unknown model
Red and black 3 drawr tool box full of mics. hand tools, box is covered in stickers
warn XD9000 non integrated
smittybilt xrc 8
23 spl NP231J transfer case
miller millermatic 250x
Thermal Dynamics Cutmaster 51
miller welding hood
Size S 150cf welsco 75% argon 25% co2 cyl.
Craftsman 36" creeper, metal frame, small rip in pad.
Craftsman 6" 1/4 drive socket driver
12inch Snap-On Pipe wrench. Orange
18inch pipe wrench (china)
Craftsman 3pc robogrip set
outlander800
That right there justifies murder. Hope you are able to recover or at least find out who dun it.
W650Mike
North Central Texas
Start cruising pawn shops within a 1 to 2 hr drive. Thieves are not only lazy but don’t seem to range very far from the hood to unload items. Even if the original B&Es don’t pawn the tools, some will end up in the hands of their drug-head friends who will get desperate and pawn stuff fairly close to where they live. Pawn shops love the druggies.
Good luck.
