Here is a gadget I built to swing two reels into three different positions.
The unit will rotate up to 180 degrees to place both reels in a garage
door opening, so that the cord and hose can be easily payed out for
outside use as well as inside use.
Inside mode
90 degree inside mode
Outside mode
The main frame is made out of 1-1/2" x 16 gauge square tube.
The door can be closed with out hitting the reels.
This is the second unit I have built like this, the first one is shown
later in this thread.
The hose reel is a Harbor Freight unit, and the cord reel is a Bayco.
Electric and air hose routing.
Locking mechanism
Custom cable clamps made from red polyurethane plastic.
These were later split down the middle with a bandsaw.
Sandblasted parts ready for primer and paint.
To unlock, just pull the lever back and rotate, the spring will
snap the keeper into place automatically.
Here is my accessory holders, they sit directly below the reel unit.
Blowguns and tire chucks go in the top, and high, medium and low
pressure gauges go in the bottom one.
These were made from store fixture shelving units turned upside down and
cut to the proper length, as the stock is about 3 feet long to start with.
Latch plate
Bottom of latch plate showing welds.
This is the first unit that I mentioned earlier.
Its been in service for about 5 years now.
This one has about 100 feet of hose on it.
Has been so handy I just had to built another for the machine shop area
as this one is in another building used for storage and support equipment.
Door open with hose payed out.
With these two units combined, its no longer a chore to air up tires, or work outside with air or electric tools.
Maybe I should patent this design (ha,ha)
Inside mode
Outside mode
Locking mechanism
Latch plate
