Hey guys I need your help. We are about to purchase a new air compressor for our garage. The garage is about 50' from the house but does have a 1 1/4" conduit buried connecting the two. I want to run a line from our home's panel to the attic of our garage where the compressor will be installed.
Since the wire will technically be underground in the conduit, will I need to use a direct burial type wire? Also the total run will be 150' max. Will 10-3 wire work? The compressor requires a 30 amp breaker but, Im kind of concerned about the length of the run. I want to wire it to a quick disconnect box and then to the compressor. Here is a link to the compressor. Most likely it will be purchased at Lowe's though. Thanks
http://www.northerntool.com/shop/tools/product_200365168_200365168
