200 amp service wire sizing
toyotadriver
Around here, the most common wire size and type that you see for 240 volt service is aluminum 4/0 4/0 2/0 or occasionally you'll see aluminum 4/0 4/0 2/0 2/0.
What is the recommended wire sizes for 200 amp service and why?
Thanks.
chickenhauler
Pennsylvania
I used 3/0 copper for mine. Pricey, but I don't like aluminum wire on or in my house. A lot depends on your electric company. Mine only required 3 lines, and then #6 ground at the service breaker.
Aceman
Eastern Oregon
There's nothing wrong with aluminum wire feeding your home.
There are a gazillion homes in the US wired with 4/0 4/0 2/0 AL. But if spending more money on copper helps you sleep at night.....
ishiboo
Oshkosh, WI
Agreed. The terminations of aluminum SE in the main panel have proven basically bulletproof. All the issues were with switch/receptacle connections. Everyone uses aluminum feeders around here.
mrb
are you actually speaking to service entrance conductors? Or a feeder?
T
toyotadriver
My house, built in 2008, has 4/0, 4/0, 2/0 aluminum wire 200 amp service.
mtne
Denver
2011NEC - Table 310.15(B)(7) Service or Feeder rating - 200A - 2/0 copper or 4/0 aluminum
Why? 'Cause it's the code. And you only want three wires for the service entrance.... hot, hot, noodle.........
v8garage
Texas
Thanks.
Where is "around here"?
V/8
mtne
Denver
V/8
Good point.......... No idea what code is outside of the USA..... and it can vary depending on where you are which edition is accepted and then it always falls to the AHJ to say what goes.
Shouldn't be too much, or any variance with services tho....
Norcal
Thanks.
That depends what the SE is for... Anything other then a dwelling & it's not correct.
